Anyone have a pioneer vsx-830k audio receiver and can pass-through the HDR signal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-13-2019, 12:08 PM - Thread Starter
Yoda23's Avatar
Hi, I have a pioneer vsx-830k audio receiver and I'm trying to update my audio receiver so can pass the HDR signal to my new samsung 4K tv that supports HDR. I've tried updating but it says I'm up to date. If you look at the change history here: https://www.pioneerelectronics.com/S...VSX-45_830.txt My version is Ver 1-307-009-008-205 and I'm trying to update to Ver 1-282-009-008-193 as you can see allows support for HDR. But it says I'm up to date and I know it is not. I even bought a new high-speed 2.2 HDMI cable and tried every HDMI port on the tv and still no HDR. I have no clue at this point how to get this working. Can anyone tell me what I'm missing or figured how you were able to update to Ver 1-282-009-008-193?
Here is the product page and click the downloads tab: https://www.pioneerelectronics.com/P...vers/VSX-830-K
Yoda23 is offline
post #2 of 2 Old 02-22-2020, 03:20 AM
Liked: 0
Hi there looks like we are the only few still stuck with pioneers vsx 830. I have a similar issue.
Mine current version 1-282-009-008-193 is already installed when I purchased it in 2017. Apparently there is no update after that.
I hooked it up with PS4 today. I found it only allows 1080i with HDR. Not 4K with HDR. I am sure my PS4 output is 4K with HDR as its perfect when directly hooked PS4 with 4K HDR TV. But not with VSX830 in between.
So it means if you successfully updated to 1-282-009-008-193, the most you will get is 1080i HDR.
Tell me if I had done anything wrong. Thanks.
Kenneth_nz is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
