Same video in HDR and SDR for comparison - Q9FN HDR Problem - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By noob00224
post #1 of 6 Old 07-18-2019, 05:54 AM - Thread Starter
Liked: 0
Hello everyone,
getting straight to the point I need to download same content with HDR and witout HDR (some quality demo or something) so I can compare both vidoes and see if I got faulty TV. I am suspecting that there is something wrong with HDR because most PS4 games seems to have higher peak brightness in SDR than HDR (SDR backlight 24/50, HDR ofc 50/50). I am sure that my TV is properly set up and connected - it detects HDR content. The problem is... this HDR contend does not look much better than SDR.
- I bought new TV - Q9FN and HDR is... not what I expected. I was using 10 yo Samsung TV so the diffrence should be noticable.
I am 100% sure that everyting is set-up correct. My TV shows its HDR signal but... I really can't tell diffrence between HDR and SDR. I am using primaly PS4 to check HDR effect - because I can turn HDR on/off very easy in most games).
In Red Dead Redemption 2 game in HDR looks worse than in SDR - I can tell that peak brightness is higher in SDR (backlight 24/50) than on HDR. Same with God of War - I heard that HDR in GoW is superb but I can brely tell diffrence.
I got professional calibration for SDR content but not HDR. For HDR I am using Local Dimming High and Contrast Enhancer, eco off and LCD motion off.
Matthew Michalec is offline
post #2 of 6 Old 07-18-2019, 06:52 AM
Quoted: 232 Post(s)
Liked: 74
2 examples: https://samples.ffmpeg.org/4khdr/
More samples here, but no SDR and HDR of the same video: https://kodi.wiki/view/Samples#4K_.28UltraHD.29
There are other sites with HDR samples on the web.
You could download from Youtube the SDR and then the HDR versions separately.
Matthew Michalec likes this.
noob00224 is online now
post #3 of 6 Old 07-18-2019, 07:16 AM - Thread Starter
Liked: 0
Thank you so much. Gonna check those out to make sure my TV is not faulty.
post #4 of 6 Old 07-18-2019, 06:03 PM
Quoted: 1848 Post(s)
Liked: 1105
What about HDMI color setting?
Sent from my LGMP450 using Tapatalk
DisplayCalNoob is offline
post #5 of 6 Old 07-19-2019, 03:14 AM - Thread Starter
Liked: 0
UHD Colour is On. HDR+ Mode off. I am not impressed by HDR in most games on PS4 but yesterday I checked Uncharted 4 and I think in daylight scenes HDR does gr8 job.
post #6 of 6 Old 07-19-2019, 03:16 AM - Thread Starter
Liked: 0
I also run multiple brightness test - static boards, clips etc. and I came to conclusion that my TV can give super-bright image. I think I just need proper sources of content : > Anyway thank you guys for help.
<-- This clip absolutly burns eyes (I know it's not natural, just wanted to check if my TV can give about 1500 nits). I just need better sources of high quality materials.
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
