HDR cannot be enabled in Windows 10, totally clueless! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By drewTT
post #1 of 5 Old 10-29-2019, 02:28 AM - Thread Starter
Liked: 1
Red face HDR cannot be enabled in Windows 10, totally clueless!
Hi guys,
Please help, I'm trying to get HDR enabled in Windows 10, but all HDR sliders under "Windows HD color settings" are still greyed out and cannot be enabled. Spent hours of testing to no avail.
Setup:
TV:
- LG E6 OLED TV (definitely HDR compatible)
PC:
- GeForce RTX 2080 Ti (definitely HDR compatible)
- Windows 10 64bit, Build 18362
What I tried (and still remember):
TV:
- Enable "HDMI ULTRA HD Deep Color" for all HDMI ports
- Make sure the latest firmware is used
- Try out all input label like "PC", " Game Console" etc..
- Use the TV as the only display connected to the PC
- Connect a NVIDIA Shield to the TV, HDR works flawlessly
HDMI cable:
- Try a HDMI 2.1 cable
- Try various HDMI 2.0a high speed cables
PC:
- Use MPC-HC/madVR to play a HDR video using HDR passthrough, it works! TV detects and plays HDR content
- Try NVIDIA settings like RGB 8bit full, YCbCr 4:2:2 8/10/12bit Limited, YCbCr 4:4:4 8 bit Limited
- Try newest and older GPU drivers
I attached an excerpt of the PCs dxdiag result. In particular these 2 lines are odd:
Monitor Capabilities: HDR Not Supported (BT2020RGB BT2020YCC )
Advanced Color: Not Supported
The values "BT2020RGB BT2020YCC" only appear when "HDMI ULTRA HD Deep Color" is enabled on the TV's HDMI port, otherwise it will only say "HDR Not Supported" without the brackets. So switching the "HDMI ULTRA HD Deep Color" at least does something. But another value "Eotf2084Supported" should appear in the brackets when the setting is enabled, but it doesn't! And obviously "Advanced Color" should say "Supported".
Does anyone have even the slightest the idea what might be wrong with my system? Thanks a lot
T-800 is offline
post #2 of 5 Old 10-29-2019, 07:57 AM - Thread Starter
Liked: 1
Oh, just remembering 2 more things I tried:
TV:
- Reset to factory settings
PC:
- Set refresh rate to 30Hz
T-800 is offline
post #3 of 5 Old 10-29-2019, 11:01 PM
drewTT's Avatar
Quoted: 2199 Post(s)
Liked: 2333
Sounds like you tried pretty much everything I can think of. Try posting in the E6 owner's thread if you haven't already. Back when I had an E6 it definitely worked for me but I think I had the 1080 card at that time.
T-800 likes this.
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL S/510 | PS Audio DirectStream | Furman IT-Reference 15i
Sony PS4 Pro | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | iFi AC iPurifier | roon
drewTT is offline
post #4 of 5 Old 11-06-2019, 07:49 AM - Thread Starter
Liked: 1
Thanks for the reply In case there is any update, I'll post it here.
T-800 is offline
post #5 of 5 Old 11-25-2019, 12:26 PM
SoNic67's Avatar
Liked: 30
Originally Posted by T-800 View Post
HDMI cable:
PC:
As I see there, you don't have an RGB 10 bit (or 12 bit) setting available. My GTX1080 connected via DP 1.2 cable to my 4k/10bit monitor shows RGB 10 bit as available.
The YCbCr 4:2:2 is a compressed format, the color is sent with 1/2 resolution of the luminance, to save bandwidth. HDMI 2.0 is at the limit of bandwidth capacity with 4k (2160p)/60Hz
Do you really use the HDMI ports on your videocard?
SoNic67 is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
