HDR Trouble. Sony Str DH790 and Sony XBR75x940D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-26-2019, 09:22 PM - Thread Starter
Liked: 0
Hello, I have an Apple TV hooked up to my Sony STR DH790 AV receiver and that hooked up to my Sony XBR75x940D TV into the HDMI 4/ARC input. Using Monoprice High Speed Active Cables for everything.
The problem I am having is getting HDR or Chroma 4:4:4 to work. I have the HDMI input set to ‘Enhanced’ on the AV receiver and TV. When I try to put in my Apple TV, I am getting a black screen. This is different then the ‘no input’ grey screen when there’s nothing going to the TV.
When I put the AV receiver from Enhanced to standard I get 4K SDR video, with Chroma 4:4:2.
I have called Sony and spoke to 2 representatives as well as one at Apple. No one seems to be able to help me, and this is really puzzling to me as my Apple TV 4K will be my primary video source now.
Thanks for the help in advance!
Tp16306 is offline
post #2 of 2 Old 11-27-2019, 05:00 PM
Quoted: 22 Post(s)
Just in case you don't get any other answers, you could try a factory reset on your receiver.
If nothing else works I'd also try another HDMI cable just to make sure.
I'm also interested in this receiver so I'm very curious how you will solve this problem in the end.
DryEyes is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
