"Fake HDR": Does it look better than SDR content on an HDR TV? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By ray0414
  • 1 Post By EvLee
  • 1 Post By SpeedDemon
  • 2 Post By EvLee
post #1 of 13 Old 11-27-2019, 04:42 PM - Thread Starter
Comp625's Avatar
Quoted: 32 Post(s)
In reference to the recent news about Disney+ and The Mandalorian using Fake HDR flags, my brother-in-law says viewing "fake HDR" content on an HDR TV still looks than viewing regular SDR content on the same HDR TV. He believes HDR TV's will handle this "fake HDR" content more accurately than SDR even though dynamic range isn't there.
True or not true? Thoughts?
Comp625 is offline
post #2 of 13 Old 11-27-2019, 07:43 PM
SpeedDemon's Avatar
Quoted: 189 Post(s)
Liked: 105
I think your brother-in-law must like the brighter look of the picture but is missing the point of HDR. If Mando was graded in SDR then it should be flagged as SDR on D+ so an Apple TV will correctly play it back in SDR and let the TV/Display use it’s calibrated SDR setting.
Playing back SDR in an HDR container results in an erroneous playback experience due to unpredictable gamma curves and dynamic tone mapping in the absence of DV metadata. I’m guessing someone at Disney incorrectly made this decision because they graded in DCI-P3 and wanted to master in Rec. 2020 instead of collapsing into Rec. 709.
This is an awkward time as the industry learns how to properly transition from SDR to HDR, but if creators want Rec. 2020 then they really need to also go all in on HDR as well to ensure a consistent playback experience. There’s no consumer standard for using Rec. 2020 after all without HDR.
Mando is SDR (in an HDR container) but its brightest elements are 200-nits (should be 150-nits). This was just a bad decision no matter which way you look at it and is what results in the washed out appearance (elevated near blacks)
With all that said, I think this could start a decent argument for using DV for 150-nit SDR masterings that takes advantage of the expanded Rec. 2020 color space because of the tone-mapping assistance provided by DV. Mando must look especially bad on non-DV HDR TVs running automated tone-mapping algos that expect 1500-nits... cough... Samsung... cough...
Spoiler!
SpeedDemon is offline
post #3 of 13 Old 11-27-2019, 11:20 PM
ray0414's Avatar
Quoted: 12860 Post(s)
Liked: 12220
There is more to hdr than just raw nits. A member over at bluray.com posted some comparison shots of some highlight detail improvement seen with hdr grading and it was quite a big difference. So there are still benefits. It may not be fake hdr but just used differently.
StayingSalty likes this.
82Q90R*75Q9FN(RIP)*55C8OLED*Galaxy Note10+*Ub820 fed into Oppo 203*XB1X*4k DenonX4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is offline
post #4 of 13 Old 11-28-2019, 04:12 AM
EvLee's Avatar
Quoted: 406 Post(s)
Liked: 419
People pay a premium for Dolby Cinema in part because of the better image quality compared to regular digital cinema. Dolby Cinema has a peak luminance twice that of regular theaters. Similarly, the "fake HDR" people are talking about goes at least twice as high in peak luminance as regular SDR. That extra stop in exposure for highlights is enough to make a big improvement in the saturation of bright colors and add detail to the image. It's not going to provide the sharp specular highlights some people may expect from HDR, but it's certainly an improvement over SDR. As far as accuracy is concerned, it depends on the television of course. In the absence of metadata to direct the tonemapping, the televisions I am familiar with will track the PQ curve accurately at least up to 200 nits before they start applying any compression to the highlights. So as long as it is set up correctly, it should reproduce the image as accurately as your calibration.
EvLee is offline
post #5 of 13 Old 11-28-2019, 04:35 AM
EvLee's Avatar
Quoted: 406 Post(s)
Liked: 419
The flaw in this argument is that even for HDR movies that do utilize 1000+ nits, they don't stay that bright all the time. Having content in an HDR container that only goes to 200 nits is not by itself going to break the tonemapping, because then all other content would also break as soon as it dips down for a darker scene. If people are seeing elevated blacks, washed out appearance, whatever... that is for an entirely different reason. Not because of the 200 nits max. The way DV works it does scene-by-scene analysis and reports max picture luminance within each scene through the metadata. As long as that metadata is generated correctly the processing in the television can adapt to any range of content inside the HDR container. But even without DV, TVs like the Samsung should be adapting their tonecurve to the content for the same reason I stated earlier. No HDR content stays at the peak luminance for its entire duration, so any algorithm has to be capable of adjusting to lower peak luminance levels.
EvLee is offline
post #6 of 13 Old 11-28-2019, 06:07 AM
SpeedDemon's Avatar
Quoted: 189 Post(s)
Liked: 105
The problem isn’t simply caused by the 200-nit max of Mando, it’s that the 150-nit SDR grading of Mando was stretched to 200-nits.
As I stated, Mando would have likely done great and looked beautiful in DV if it were left at 150-nits.
The primary reason HDR10 would have a problem vs DV with 150-nit content/scenes is due to the way the HDR tone mapping algorithms will typically artificially brighten many scenes on most displays.
Spoiler!
post #7 of 13 Old 11-28-2019, 08:12 AM
EvLee's Avatar
Quoted: 406 Post(s)
Liked: 419
That's certainly news to me considering the televisions I have calibrated will take an HDR10 signal and display it to a nearly identical match when compared against a reference mastering monitor. Maybe try disabling any additional HDR processing if you are seeing it pump the brightness up.
As for 150 nits... SDR doesn't get graded at 150 nits. It is done at 100 nits reference. Doesn't matter what studio or facility is doing the work, that's the standard everybody has to follow. It's also been shown with screen captures in other threads that the Mandalorian is not a stretched SDR grade. There is highlight information and color in the HDR image that simply does not exist in the SDR version.
SpeedDemon likes this.
EvLee is offline
post #8 of 13 Old 11-28-2019, 10:21 AM
SpeedDemon's Avatar
Quoted: 189 Post(s)
Liked: 105
You’re right. I meant to say 100-nits.
I agree that disabling the extra HDR10 processing for dynamic tone-mapping would fix some of the issues I described, but my experience has been that all proper HDR10 material benefits from this setting being enabled. I think this will remain true until we have displays capable of true 10k-nits of range.
With that said, certain TVs like Samsungs don’t follow a reference EOTF curve regardless while in an HDR picture mode and are going to always throw things off but that’s kind of a different problem.
That’s news to me that Mando isn’t stretched from 100 to 200 nits though. Any source for this?
EvLee likes this.
Spoiler!
post #9 of 13 Old 11-28-2019, 03:16 PM
EvLee's Avatar
Quoted: 406 Post(s)
Liked: 419
These screenshots were shared in the Disney+ thread.
http://www.framecompare.com/image-co...rison/DGWKGNNX
http://www.framecompare.com/image-co...rison/JE0FMNNU
If you compare the SDR to HDR you can see the HDR contains much more detail in the highlights, as well as additional color. Look inside the core of the flames. If the SDR had been stretched to make HDR it would be lacking all that information.
You may be right about the Samsungs. Most of the televisions I have set up have been LG, Sony or Panasonic. Samsung seems determined to do everything their own way.
SpeedDemon and Casey_Bryson like this.
EvLee is offline
post #10 of 13 Old 11-28-2019, 09:36 PM
SpeedDemon's Avatar
Quoted: 189 Post(s)
Liked: 105
There's clearly a difference in those images as you point out, but do you think that it's possible that Disney simply didn't produce an SDR encode of Mando and that this is a result of tone mapping being performed by whatever device the D+ app is running on?
Spoiler!
post #11 of 13 Old 11-30-2019, 08:54 AM
SoNic67's Avatar
Liked: 30
This a re-hash of the old discussion about audio mp3 files and various software solutions that will "enhance" them to sound "like" CD quality. I personally never found that to actually make a positive difference.
Same here - if the program was not recorded in HDR (bit-depth) then something else that fakes that HDR will not look better. Might look "different" due to mapping, but... gamma adjusting could do the same.
SoNic67 is offline
post #12 of 13 Old 12-11-2019, 01:44 AM
ray0414's Avatar
Liked: 12220
Need your opinion on this. Vincent is disputing those screenshot comparisons, and it looks like hes brought up some great points. He was able to take the SDR version and using Divinci, lower the gain of the SDR version and "create" all the hdr detail right in the SDR version. Doing this lowered the APL, which matches the lower APL of the HDR version of the Mandalorian. So did they run a lot of their content through an system/process that just does a quickie HDR grade instead of doing it all manually? Hence why all those HDR grades are dull and dim? check out Vincents quick demonstration.
ray0414 is offline
post #13 of 13 Old 12-28-2019, 06:31 AM
Anderegg's Avatar
Quoted: 521 Post(s)
Liked: 309
I just spent the last hour trying to find a way to bypass HDR on Disney Plus to watch The Mandalorian. First tried my Fire TV...there is no way to turn off HDR on Fire TV. Next, I tried an old Android TV box...it allows you to do HDR to SDR, but no way to disable HDR metadata from Disney, so that doesn't work either. Tried downloading the DIsney Plus app in the Wndows Store, although it says requires X Box OR Windows 10 PC, the app only works on X Box...so that didn't work either. I then tried my Windows 7 PC watching in Chrome...yay, it works, SDR, but no DD+ audio. But wait, there is a Chromecast button in the corner, pressed that, sent to my Sony X900F TV, yay ya yay, proper SDR with proper DD+ with proper 24Hz playback.
Why all the trouble to see this in SDR? My SDR calibrated picture has a black level of 0.028cd/m with 100nit brightness. The black level on my HDR calibration is 0.16cd/m with peak 820nit available in HDR10 or DV. Watching 200nit peak brightness content with a 0.16cd/m blakc level is HORRIBLE. Maybe if you have an OLED it would look better, but for an LCD TV, it's garbage. You can do the math on contrast levels for the above specs I listed.
Paul
Sony X900F SDR and HDR Calibrations https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is offline
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
