LLDV vs Dolby Vision - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By MMoser
post #1 of 8 Old 02-22-2020, 08:07 AM - Thread Starter
Liked: 1
I'm struggling to find what devices support LLDV, or how it's different that regular Dolby Vision. Is there a list somewhere? I'm hoping Chromecast would, but I can't seem to confirm.
miketunes is offline
post #2 of 8 Old 02-22-2020, 09:00 AM
MMoser's Avatar
Quoted: 91 Post(s)
Liked: 30
Apple TV 4K and Shield 2019 both do LLDV, also Sony 4k disc players. Main difference between full DV and LLDV is the source player will apply the tone mapping for LLDV, where full DV will happen on the actual TV if supported. Sony and some LG TVs use LLDV, so the source player applies the tone mapping and sends the signal wrapped in a HDR RGB container. A couple Hdfury devices will let you fake your edid to get a DV stream to a non-DV display, like a projector. I use a Vertex2 with ATV4K and Shield to get the LLDV stream sent to my Projector. Works great!
Sent from my SM-N975U using Tapatalk
Dominic Chan and Archibald1 like this.
MMoser is offline
post #3 of 8 Old 02-22-2020, 09:07 AM - Thread Starter
Liked: 1
Did you ever test a Chromecast by chance? If that doesn't support LLDV I may buy a Shield to watch DV netflix shows.
post #4 of 8 Old 02-22-2020, 09:13 AM
MMoser's Avatar
Quoted: 91 Post(s)
Liked: 30
I don't have a CC Ultra to test with as I use the Shield19 to cast, but it looks like the product page only lists DV for the Ultra. Being that there is some video processing happening to do LLDV I'd be surprised if the the CCU can do anything other than pass through.
https://blog.google/products/chromec...d-hdr-support/
MMoser is offline
post #5 of 8 Old 05-08-2020, 02:44 PM
Liked: 0
Does anyone know if the Panasonic dp-ub450 supports lldv output?
hthamalainen is offline
post #6 of 8 Old 05-11-2020, 10:49 AM
Archibald1's Avatar
Quoted: 2745 Post(s)
Liked: 1734
I would venture that if it says it supports DV, then LLDV (or profile 5 as it is otherwise known) should also be supported.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking. ~~~ "Be water my friend." Bruce Lee.
Archibald1 is offline
post #7 of 8 Old 05-21-2020, 07:26 AM
Liked: 1
What is better HDR10 or DV
David Siegel is offline
post #8 of 8 Old 05-21-2020, 08:41 AM
Archibald1's Avatar
Liked: 1734
On a film without much luminance variance, I would say it is a close call with a decent curve in use, but for a lot of HDR with dark scenes and light scenes, then DV with its dynamic metadata wins out I think.
Reply High Dynamic Range (HDR) & Wide Color Gamut (WCG)
