Paladin DCR-C Pre-Order Program - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #1 of 64 Old 02-19-2020, 08:25 PM - Thread Starter
Shawn Kelly's Avatar
Quoted: 203 Post(s)
Liked: 157
MANY THANKS TO EVERYONE WHO PARTICIPATED! We will be taking down this thread in the near future since the pre-order program is now closed. Since the Paladin DCR-C is indeed a DCR lens, please post any follow-up comments in the Paladin DCR Owner's Thread.
OzHDHT and Craig Peer like this.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
Shawn Kelly is offline
post #2 of 64 Old 02-20-2020, 06:10 AM
rhbblb1's Avatar
Quoted: 77 Post(s)
Liked: 31
I was in with the Phoenix DCR, but the Paladin-DCR has a throw distance that is too long for me. I have a JVC RS-2000 with a throw distance of 1.6.
rhbblb1 is offline
post #3 of 64 Old 02-20-2020, 06:19 AM
rhbblb1's Avatar
Quoted: 77 Post(s)
Liked: 31
I’m in if the new C-DCR can get me to 1.6:1 on my RS2000.
rhbblb1 is offline
post #4 of 64 Old 02-20-2020, 06:24 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
That's possible. We're looking at some customizations of the C-DCR for some specific projectors including the RS2000 that can get it closer to the projector lens to support the lower ratio.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #5 of 64 Old 02-20-2020, 06:37 PM
Liked: 0
I’m in if throw distance is not a problem with my setup. I’m getting a Sony vw295es.
ht2020 is offline
post #6 of 64 Old 02-20-2020, 08:44 PM
Jay_Fi's Avatar
Liked: 0
I'm in.
Joe
Jay_Fi is offline
post #7 of 64 Old 02-22-2020, 06:32 AM
12GAGE's Avatar
Quoted: 364 Post(s)
Liked: 409
I'm in for my vw 1100. I missed out on the DCR lens in the past. I should be about a 2.0 throw ratio. Will it handle a large lens like on the VW 1100 ?
12GAGE is online now
post #8 of 64 Old 02-22-2020, 08:27 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
It's possible. As a minimum, you wouldn't be able to use the lens door - the C-DCR would need to get right up to the 1100 lens. At 2.0:1 TR your beam should be small enough. However, please fill your screen with a bright image, then put a piece of paper at the front of the lens and measure the beam spot height and width on the paper. That way we should be able to confirm compatibility.
Side note though - the 1100 doesn't have 4K anamorphic processing - only 1080. You'd need a Lumagen processor for full 4K/4096 anamorphic.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #9 of 64 Old 02-22-2020, 11:24 AM
12GAGE's Avatar
Quoted: 364 Post(s)
Liked: 409
Thanks Shawn. I will measure the height and width. I am using an HTPC and Jriver so the scaling is covered there.
post #10 of 64 Old 02-22-2020, 03:47 PM
OzHDHT's Avatar
Quoted: 1320 Post(s)
Liked: 823
I'm in for my NX7. Who'd have thought I'd end up with two JVC projectors and two Paladin's .
Shawn Kelly likes this.
OzHDHT is offline
post #11 of 64 Old 02-23-2020, 07:18 AM
mkerdman's Avatar
Quoted: 132 Post(s)
How is the Paladin-C DCR "Identical in use and performance to the standard Paladin DCR lens", and how does it differ?
Murray Kerdman
mkerdman is offline
post #12 of 64 Old 02-23-2020, 08:51 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Hi Murray. The only difference is that the Paladin-C DCR is a more compact version of the standard Paladin DCR. Because it is smaller it can only work with smaller beams that result from higher throw ratios. The Paladin DCR can go down to a throw ratio of 1.4:1 whereas the Paladin-C DCR can only go down to 1.6:1 for targeted Sony and JVC projectors, and a higher minimum throw ratio for other projectors. Other than that - it's the same technology, same performance - just smaller optics.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #13 of 64 Old 02-23-2020, 06:03 PM
mkerdman's Avatar
Quoted: 132 Post(s)
Shawn, thanks for the explantion.
Murray Kerdman
mkerdman is offline
post #14 of 64 Old 02-25-2020, 07:37 AM
Quoted: 116 Post(s)
Liked: 35
I am in for NX7.
Satya b
satyab is offline
post #15 of 64 Old 02-25-2020, 11:59 AM
asharma's Avatar
Quoted: 2354 Post(s)
Liked: 868
NX7 Lens is back 14’5” from 115” wide screen...will that work?
asharma is online now
post #16 of 64 Old 02-25-2020, 12:19 PM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 763
So does that mean for the RS3000/NX9 you are limited to the 1.8:1 throw ratio?
Killroy is offline
post #17 of 64 Old 02-25-2020, 12:49 PM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
I believe that puts you @ 1.5.1, which is also my minimum throw distance. Paladin says 1.6.1 minimum throw due to its compact design. You may have to go non-compact, I hope I'm incorrect and it can go @ 1.5.1, then I would probably purchase as well. I can't afford the non-compact model.
Peace and blessings,
Azeke
Azekecse is online now
post #18 of 64 Old 02-25-2020, 09:05 PM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Possibly higher because the RS3000 lens is so huge. I should have a better idea on that next week.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #19 of 64 Old 02-25-2020, 09:05 PM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Indeed, unfortunately 1.5:1 is too low.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #20 of 64 Old 02-26-2020, 05:17 AM
Clark Burk's Avatar
Quoted: 761 Post(s)
Liked: 697
So 1.6 throw ratio minimum for NX5, NX7, RS1000, and RS2000. Any restrictions as far as mounting ceiling vs shelf mount or inverted as far as placement in relation to the screen? Looking at the pictures the plate mounts to the bottom or the side with the feet. Is there enough adjustability to provide for above screen mounting if close to the 1.6 ratio?
I'm guessing the lens is going to have to be placed very close to the lens on the projector. I was thinking this might reduce some of the mounting possibilities in relation to the screen due to the limited adjustability because of the compactness of the lens. In other words is shelf mounting at close to the minimum throw going to limit my placement to dead center of the screen and how much flexibility is there in the placement at minimum throw?
Clark
Clark Burk is offline
post #21 of 64 Old 02-26-2020, 05:50 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
That's a great question! We do indeed take into account that projectors are typically vertically mounted at or above the screen top, and that the farther above, the more the beam comes out of the lower section of the projector lens. So yes, the C-CDR will work at the 1.6:1 ratio from at or above the screen top (perhaps up to 10") and will also work with the projector either shelf or ceiling mounted.
Tom Bley likes this.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #22 of 64 Old 02-26-2020, 08:37 AM
Tom Bley's Avatar
Quoted: 979 Post(s)
Liked: 957
Shawn,
I just wanted to confirm. I have a JVC RS-2000. 122" width image. 19ft from screen. lens about 6" above top of screen. I am calculating a 1.87 ratio so, I should be good to go, yes?
Also, It reads Paladin-C DCR approximatley 43% brighter. The standard Paladin DCR I thought was at 38%? Why is this different if it's just a more compact lens? Marketing? lol
"2.6 million pixels and roughly 43% higher brightness compared to the standard letterbox image"
Tom Bley is online now
post #23 of 64 Old 02-26-2020, 09:05 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Originally Posted by Tom Bley View Post
Shawn,
Hi Tom,
Yes, your theater is good to go.
We always like to qualify our enhancement numbers by "compared to what?" If the projector is in normal letterbox mode then the enhancement is 2.6 million more pixels. If you compare the anamorphic setup to the "Zoom" non-anamorphic setting in the projector that can take letterbox to 4096 wide then the enhancement is 1.7 million more pixels.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #24 of 64 Old 02-26-2020, 09:30 AM
nonstopdoc1's Avatar
Quoted: 931 Post(s)
Liked: 402
Here is my current setup
Projector - JVC X790R
Current Projector to Screen distance - 19' 5"
Screen width - 133" (2.39:1)
Throw Ratio - 1.75
I am thinking of waiting till CEDIA to see if JVC releases a successor to NX7.
Will this len maintain compatibility with future JVC lineup or is there no way to confirm that at this time?
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | JBL SDP-55 | Nord NC500 | ATI AT528NC | Procella P8/P5V | Revel C763L | Monolith 12" x4
Living Room - LG OLED 65" | Denon X4400H | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Rythmik FV15HP x2
nonstopdoc1 is offline
post #25 of 64 Old 02-26-2020, 09:47 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Throw Ratio - 1.75
No way to absolutely confirm at this time. I doubt they would go away from 4096/4K resolution or a substantially different projector/lens design that would make the C-DCR not work (for example, extremely recessed) but that's only a guess.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #26 of 64 Old 02-26-2020, 10:36 AM
brazensol's Avatar
Quoted: 826 Post(s)
Liked: 690
Any idea when the next "B" stock sale will come along?
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #27 of 64 Old 02-26-2020, 10:41 AM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
On the regular Paladin DCR? If at all this year it would be perhaps August. B-Stock DCRs are extremely rare.
brazensol likes this.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #28 of 64 Old 02-28-2020, 11:44 AM
beastaudio's Avatar
Quoted: 5810 Post(s)
Liked: 5669
How big of a difference are we talking with a throw distance on an rs2000 1.8 vs 1.6 Shawn? Noticeable?
beastaudio is offline
post #29 of 64 Old 02-28-2020, 12:17 PM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
The only perhaps noticeable difference between 1.6:1 and 1.8:1 would be slightly less distortion towards the image edge at the 1.8:1 but even at 1.6:1 that will be hard to see once masked with the screen border.
beastaudio likes this.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #30 of 64 Old 03-02-2020, 07:26 PM - Thread Starter
Quoted: 203 Post(s)
Liked: 157
Update: The pre-order price will increase from $3,495 to $4,495 on Friday, March 13, 2020.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
Reply Panamorph 4K UltraWide Cinema
