Hitachi 57f500a black screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-09-2013, 09:52 PM - Thread Starter
markero's Avatar
Several weeks ago, my Hitachi developed a blue line across the top and blue ghosting on all lettering that was on the screen.I installed two new convergence chips on Saturday and while putting the front panel on,I hit it with my palm. The tv began to go dim and soon it was black. I took the back panel off and checked all of my connections and then all of the connections on all the equipment hooked to the tv.The tv refused to come back on until I became frustrated and hit the front of the tv with my palm and presto,it came back on. It stayed on about 30 minutes before it went dark again. Each time it does this,I can still hear the audio and the power button is still lit. I've done this several times since Saturday with the longest it's stayed on about 3 hours. I finally decided that I wasn't doing it any favors by hitting it and turned it off.I love the tv and it's got a beautiful picture since the chip replacement . Does anybody have any suggestions about what might be causing this problem? Thanks. Markero.
markero is offline
post #2 of 3 Old 09-11-2013, 11:45 AM
tanveers's Avatar
I would suggest having a Certified technician take a look at it. From what you have said, it sounds to me like you may have some connections in your video circuitry loose, or your likely to have one of your capacitors or fuses starting to fizzle out and blow. If I'm correct this is an outdated TV. It may be difficult to find parts anymore, so unless you fixed them in the past, call a local technician to diagnosed and resolve the issues.
Ben
Lead AV Tech, AA Rental
tanveers is offline
post #3 of 3 Old 09-11-2013, 12:28 PM
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
I would suggest asking your question at the below thread...
https://www.avsforum.com/t/695922/dont-dump-your-crt-rptv/11850#post_23722269
You'll get a better response there.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Reply Rear Projection Units
