Mitsubishi DLP has weird yellow blotches - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Transistorious
post #1 of 15 Old 03-26-2019, 04:50 AM - Thread Starter
MrDSL's Avatar
Liked: 1
Can someone please tell me what these yellow blotches are on my Mitsubishi DLP?
MrDSL is offline
post #2 of 15 Old 03-29-2019, 11:59 AM
solarrdadd's Avatar
Quoted: 287 Post(s)
Liked: 182
don't know if it's the same type of tech as my old Sony SXRD, but, it looks like a failing Optical Block rearing it's ugly head. or whatever the DLP term is. had that tv for 10 + years before going 4K to replace it.
i'm sure someone with a Mitsi DLP that has experienced that will be along shortly. best of luck
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XPA5,UPA2, UPA200 & Mini X Amps
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is offline
post #3 of 15 Old 03-29-2019, 12:08 PM
Transistorious's Avatar
Quoted: 83 Post(s)
Liked: 48
Digital Light Processing >>>>D L P, developed by Texas Instruments, check:
https://en.wikipedia.org/wiki/Digital_Light_Processing
Calum Cahil likes this.
Transistorious is offline
post #4 of 15 Old 03-29-2019, 12:11 PM
solarrdadd's Avatar
Quoted: 287 Post(s)
Liked: 182
that i knew, i meant, if DLP has a different name for what SXRD referred to as an Optical Block.
post #5 of 15 Old 03-29-2019, 12:13 PM
Quoted: 83 Post(s)
Liked: 48
that i knew, i meant, if dlp has a different name for what sxrd referred to as an optical block.
Du l y N o t e d
solarrdadd likes this.
post #6 of 15 Old 03-29-2019, 12:16 PM
solarrdadd's Avatar
Quoted: 287 Post(s)
Liked: 182
d u l y n o t e d
in the Sony SXRD's, when the Optical Block began to fail, you knew it because you started getting yellow/greenish blobs on the screen. i had the OB replaced in my old SXRD 3 times and the 3rd time was the charm as it lasted 10 years till i sold it last year when i got my 4K tv and being in touch with the purchaser, it's still working like a charm!
post #7 of 15 Old 03-29-2019, 12:25 PM
Quoted: 83 Post(s)
Liked: 48
My humble suggestion is to VERY carefully remove the back cover. Hopefully you have a cordless screwdriver that will make the task a lot easier. Then check for spider webs. If so, again VERY carefully use the vacuum cleaner narrow spacer attachment to remove then. Once more make sure to avoid any contact or you will do some scratching damage.
Good luck
post #8 of 15 Old 03-29-2019, 12:29 PM
solarrdadd's Avatar
Quoted: 287 Post(s)
Liked: 182
also, when was the last time you changed the lamp?
post #9 of 15 Old 03-29-2019, 12:38 PM
Quoted: 83 Post(s)
Liked: 48
Super great point, you are now Sir solarrdadd
post #10 of 15 Old 03-29-2019, 12:58 PM
solarrdadd's Avatar
Quoted: 287 Post(s)
Liked: 182
post #11 of 15 Old 03-29-2019, 01:02 PM - Thread Starter
MrDSL's Avatar
Liked: 1
Good luck
i did this a few weeks ago
MrDSL is offline
post #12 of 15 Old 03-29-2019, 01:03 PM - Thread Starter
MrDSL's Avatar
Liked: 1
i did this the same time i cleaned with vacuum...i usually go through 2 lamps a year
MrDSL is offline
post #13 of 15 Old 03-29-2019, 01:06 PM - Thread Starter
MrDSL's Avatar
Liked: 1
thank you..ill do a search and see if mine has that..hopefully someone familiar with DLP recognizes this
MrDSL is offline
post #14 of 15 Old 03-29-2019, 02:06 PM
Quoted: 83 Post(s)
Liked: 48
Check this link:
https://www.avsforum.com/forum/63-re...thread-13.html
Have you had this TV DLP chip replaced? What is your TV model number? eBay has some Mitsubishi OBs for sale.
Again good luck!
post #15 of 15 Old 03-29-2019, 02:16 PM - Thread Starter
MrDSL's Avatar
Liked: 1
Check this link:
Final question, have you had this TV DLP chip replaced?
Again good luck!
Ill check the link.. no have only ever had to replace bulbs
MrDSL is offline
Reply Rear Projection Units
