2nd HAnd JVC DLA-HD750 Worth Buying?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-03-2019, 01:17 AM - Thread Starter
Liked: 0
Hi all, I am a newbie when it comes to projectors. I am using and old Epson TW5200. So thinking of upgrading to something a bit better and hopefully resolve that dreaded screen bowing (slightly bowing on bottom edges).
The problem here is that the HD750 is a very good projector but also very old model. Hence, I am not even sure if its worth buying it 2nd hand (considering the age and reliability).
I am not into 4K for now. Just HD movies and in my room (screen is around 100") So, need to ask for some advice. With the same money (around SGD750 or USD550) is it worth buying this projector or should I get something else??
Thanks for the help!!
escksu is offline
Reply Rear Projection Units
