how to connect ext ant to portable tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-20-2018, 10:55 AM - Thread Starter
Izlude's Avatar
Hi all, I got a nice Panasonic TR-205 portable TV. Very vintage looking, very cute stuff. Bah.. it has an ext-ant port in the back, and a 3.5mm jack was just a tad bit "too thin"... is there anything a tad bit larger? but not super fat like those mega karaoke jacks. what's the next step above 3.5?
Anyway, from there, do I still have to connect it to a uhf/vhf adapter, an then from that adapter, go to a 75 to 300 ohm to coaxial adapter before going composite?
Steps would be appreciated. It's for hobby purposes, not trying to watch TV. I might wanna display some content from the PC onto it for store display etc... fun stuff! Thanks!
Izlude is offline
post #2 of 3 Old 07-20-2018, 11:38 AM
Ratman's Avatar
Quoted: 2247 Post(s)
Liked: 2110
Cute, but the tuner is obsolete. No antenna will work or pick up/decode any OTA signals.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 3 Old 07-25-2018, 10:02 PM
AlienWarlock's Avatar
Hey while we are on the topic of obsolete.... How about radio shack....
I think this is what you want: https://www.radioshack.com/products/standard-f-plug-to-1-8-jack
"Use this F-Connector Female Jack to 1/8" Plug Adapter to enhance the picture and sound of your portable TV by connecting an external antenna."
I have one of these in a box somewhere. I used it to connect an external antenna to a pocket TV once. You should be able to drive your TV with the RF output of a VCR or anything else with Ch 3/4 RF output.
No VCR, no problem... Just get one of these for direct conversion of composite video to RF: https://www.amazon.com/RCA-Compact-R.../dp/B0014KKV7W
My semi-dedicated theater: The EXASCALE CINEMA
AlienWarlock is offline
Reply Direct View (single tube) CRT Displays
