Phillips 28PT7007/12 Service Menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-08-2018, 04:17 AM - Thread Starter
Liked: 0
Hello, i tried out the following codes i found on the net:
PHILIPS-1
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu.
PHILIPS-2
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
PHILIPS-3
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
PHILIPS-4
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
PHILIPS-5
* With the TV off:
But the only thing that happens when i input them is that it says "Dealer" and "Service Default" in the lower right corner of the screen and all my settings for brightness, contrast, volume, etc are getting reset.
Any ideas how i could enter the real menu?
Andreas Kefalas is offline
Reply Direct View (single tube) CRT Displays
