Attempt RGB Mod on Mitsubishi CS-40809 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-26-2018, 02:19 PM - Thread Starter
Izlude's Avatar
Edit: I now require a service manual for Mitsubishi CS-40809. I have asked mitsu directly but they are playing coy with me... they don't want to search their archives because they said it will take months. I have lots of time, but as long as I can get THE right copy, that's fine... so I might need to ask the community here for help. If you guys have a service manual or schematic so I can look at the Jungle IC's pin-out, please let me know..
I did manage to install a new power cord. Used some chicken pliers (pvc pipe as handles) to grab the old cord's clip and pull it out. It was very close to the flyback and anode wire, so just in case I bump my fingers in there, it was worth it to build these custom pliers.
The set does work, here's some photos. I would really love to get RGB going for some of the old computers and consoles.
https://imgur.com/gallery/lV9mqlt
Thanks guys!
Izlude is offline
Reply Direct View (single tube) CRT Displays
