Out of these TVs, which one is the best and most practical? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By The Lizard King
post #1 of 4 Old 12-03-2018, 09:58 PM - Thread Starter
Liked: 0
Hi all, I'm thinking of buying or getting a free CRT TV. I can get a JVC AV-32320 for like 10 bucks, or I can even get a 32" JVC I-Art "flat screen" for free from someone else. I believe the curved, 32" AV-32320 is in pretty good condition. The I'art seems fine too, but it is from someone who is giving away several CRTs, including a Mitsubishi (I think it's a 32" also), and a few Sharp 27" crts. The 27" Sharp might be lighter and fit in the space I tend to use it in easier. I will be using it, ideally, about two to three feet away, but not more than that, on the edge of the corner of a table. The 32" TVs might be more cumbersome, and I don't know if being that close to a 32" tv will cause headaches or not. I know Sharp made "okay" CRT tvs... I had a small one years ago, and it was average at best. I think either JVC TV (I'm leaning towards the AV-32320), because I like the black frame/bezel and I think it will be a little lighter, too. I'm just afraid any 32" might be on the big side. Let me know if its better to just go with a 32" TV, or if I should downsize to a 27" CRT TV... then the real question is if the 27" Sharp will stand a chance in picture quality compared to a JVC CRT TV. Thanks, let me know what you guys think.
Kevin Arora is offline
post #2 of 4 Old 12-12-2018, 01:22 AM
The Lizard King's Avatar
I vote for neither.
Find a SONY with a super fine pitch tube. You can get these for free and/or very cheap too.
https://en.wikipedia.org/wiki/FD_Trinitron/WEGA
Bruce2019 likes this.
The Lizard King is offline
post #3 of 4 Old 03-02-2019, 12:13 AM
Liked: 0
Find a SONY with a super fine pitch tube. You can get it.
painewaide is offline
post #4 of 4 Old 03-17-2019, 05:04 PM
Bahn Yuki's Avatar
Quoted: 239 Post(s)
Liked: 135
Send a message via AIM to Bahn Yuki Send a message via MSN to Bahn Yuki Send a message via Yahoo to Bahn Yuki
Jvc i'arts are great sets.
Sent from my SAMSUNG-SM-G891A using Tapatalk
JVC RS400, Denon X6300H, Klipsch RP-280F x 2, RP-450C, RB-51 II x 2, RS-42 II x 2, RB-41 II x 2, R-150M in 7.1.4, 150" Silver Ticket
LG 65C7, Denon X4300H, Klipsch RF-26 x 2, RC-52 II, Onkyo speakers in 5.1.4 setup
TCL 55P605, Klipsch 2.1 Certified THX speakers
Sony 34XBR960 x 2
Bahn Yuki is offline
Reply Direct View (single tube) CRT Displays
