13" Sony KV-13FS100 CRT TV - Retrace lines and turn on time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-23-2019, 01:49 PM - Thread Starter
Liked: 0
Hi. I am looking to adjust the screen voltage on my 13" Trinitron I recently picked up - KV-13FS100 due to retrace lines. Should I use this plastic screwdriver for the adjuster on the flyback transformer?
ebay.com/itm/6-Pc-TV-Radio-CB-Ham-Alignment-Tool-Kit-Set-Philmore-63-8454-NIP/122426208479?hash=item1c812bb0df:g:IbMAAOSwQaJXRQL z
Also, it takes a while to turn on with the red light constantly blinking. Is this normal?
youtube.com/watch?v=bvjBawfm4sM
cbo2188 is offline
post #2 of 2 Old 12-03-2019, 08:56 AM
brandavies's Avatar
Liked: 0
According to the service manual, the flashing light can indicate a problem. The number of times the light flashes corresponds to different possible errors.
I can't post links, but google "13FS100" service manual and pick the one from manualslib and it should be on page 7.
brandavies is offline
Reply Direct View (single tube) CRT Displays
