Samsung TX-S3079WH HDMI issue with XBox 360 E - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rabbit73
post #1 of 24 Old 12-20-2019, 10:34 AM - Thread Starter
kblackburn101's Avatar
Quoted: 41 Post(s)
Liked: 2
Got an old hdtv with only one hdmi and it does not seem compatible with Xbox 360 e .
How do you manage to expand the output capabilities.
Samsung slim fit 30” widescreen . Older model first gen hdtv 2005
Im Asking for a suggestion for a cheap switcher, or am I better off buying a used receiver??
* I am not using a switcher**
Reptilians invading in year 2027
Tesla spoken to them
kblackburn101 is offline
post #2 of 24 Old 12-20-2019, 11:05 AM
Ratman's Avatar
Quoted: 2496 Post(s)
Liked: 2317
HDMI is backwards compatible. New(er) should work with old.
The TV has in "input".
Are you using a switch(er)? Which one? (make/model)
If using a "switcher"... what's on the other input?
If you disconnect the other device from the "switcher", does the Xbox work?
Does the Xbox work directly connected to the TV?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 24 Old 12-20-2019, 11:10 AM
Otto Pylot's Avatar
Quoted: 3655 Post(s)
Liked: 2629
Technically yes, but only to the in-common option sets. An HDMI 2.0 source to HDMI 1.3 sink for example will only utilize the option sets that are available to HDMI 1.3.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #4 of 24 Old 12-20-2019, 11:14 AM
Ratman's Avatar
Liked: 2317
Yes... that's backward compatibility.
post #5 of 24 Old 12-20-2019, 11:26 AM
Otto Pylot's Avatar
Liked: 2629
It is the Holiday Season so I'll be nice However, if the OP is trying to push anything more than 1080, it may be an HDMI chipset issue.
post #6 of 24 Old 12-20-2019, 11:59 AM
Ratman's Avatar
Liked: 2317
I don't understand the statement in regard to being "nice".
Perhaps the OP needs to provide "specific" info before two contributors (that typically agree over the years) start lobbing snowballs at each other.
post #7 of 24 Old 12-20-2019, 11:59 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 2
Old hdmi switcher ? Or something
Tv is 1080i.
Im Asking for a suggestion for a cheap switcher , hdmi works with my Blu-ray player but not the Xbox 360. So it’s not the hdmi issue
post #8 of 24 Old 12-20-2019, 11:59 AM
rabbit73's Avatar
Quoted: 937 Post(s)
Liked: 415
Wouldn't that be expand the input capabilities of the TV?
https://www.lifewire.com/hdmi-switchers-basics-4158344
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #9 of 24 Old 12-20-2019, 12:04 PM
Ratman's Avatar
Liked: 2317
Please.
What EXACTLY is the non-compatibility issue?
What capability(s) are you trying to "expand"?
I ask again for you to provide details. Thanks in advance.
post #10 of 24 Old 12-20-2019, 12:10 PM
Ratman's Avatar
Liked: 2317
Then you are just looking for an HDMI 2X1 switch and presently have no issue? Correct?
post #11 of 24 Old 12-20-2019, 12:16 PM
Ratman's Avatar
Liked: 2317
Tv is 1080i.
Can you explain what the problem is with your Xbox and the 1080i TV?
Why (or what) do you think a "switcher" will solve the problem with the Xbox and the TV?
post #12 of 24 Old 12-20-2019, 12:37 PM
Otto Pylot's Avatar
Liked: 2629
I'm just playin' with ya
post #13 of 24 Old 12-20-2019, 12:39 PM
Otto Pylot's Avatar
Liked: 2629
Tv is 1080i.
For 1080i, you shouldn't have any HDMI hardware issues. I'm with Ratman, we're not quite sure what the issue is.
post #14 of 24 Old 12-20-2019, 01:03 PM
Ratman's Avatar
Liked: 2317
We're fine.
Just can't tell anymore with some of the nonsense over the past few months which is a "nudge, nudge" or a poke in the nose.
post #15 of 24 Old 12-20-2019, 01:36 PM
Otto Pylot's Avatar
Liked: 2629
We're fine.
Yep. I agree. I'll try to be a little more obvious with my "humor".
post #16 of 24 Old 12-20-2019, 01:46 PM
rabbit73's Avatar
Quoted: 937 Post(s)
Liked: 415
HDMI was an invention born of greed for copy protection. Compatibility was an afterthought.
On HDMI switchers with two HDMI outputs that send the same video signal to two video displays, if one of the displays has a lower resolution (e.g. one is 720p and the other is 1080p, or one is 1080p and the other is 4K), the output from the switcher may default the lower of the two resolutions for both displays.
The {HDMI} splitter also has to be compatible with the video and audio signals you may need to pass-through. Just as with a switcher, if one video display device is a lower resolution than the other, the output for both may default to the lower resolution.
Or something
Component?
DrDon likes this.
Lord Kelvin, 1883
rabbit73 is offline
post #17 of 24 Old 12-20-2019, 02:31 PM
Super Moderator
DrDon's Avatar
Quoted: 2377 Post(s)
Liked: 4559
TX-R3079WH?
If so, you might try some of the Samsung threads in the CRT Displays section. Might be a known issue.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #18 of 24 Old 12-21-2019, 06:44 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 2
We're fine.
I need more hdmi inputs and I’m not sure why Xbox 360 won’t work if Blu-ray works fine ?? Wtf
post #19 of 24 Old 12-21-2019, 07:41 PM
rabbit73's Avatar
Quoted: 937 Post(s)
Liked: 415
Samsung TX-S3079WH
Thank you. Looks like DrDon had a close model number.
I need more hdmi inputs and I’m not sure why Xbox 360 won’t work if Blu-ray works would work.fine ?? Wtf
I don't think you you have told us how it doesn't work. No picture, bad picture, or what with HDMI cable?
If you can't get it to work with HDMI using an HDMI cable from the XBox, I wonder if an HDMI splitter or switcher from the XBox would work.
If HDMI doesn't work, maybe an HDMI to component converter from the XBox would work.
Name:	Samsung TX-S3079WH connections.JPG
ID:	2657216   Click image for larger version
Name:	XBox360 E Back View2.jpg
Lord Kelvin, 1883
rabbit73 is offline
post #20 of 24 Old 12-21-2019, 08:37 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 2
No picture but tv can tell something is hooked in . Works fine for lg Blu-ray player so it’s clearly something about the Xbox that just does not work are you saying it’s better to buy components inputs for it ? What’s that $20?
I wonder why Xbox won’t work different type of hdmi ?
post #21 of 24 Old 12-22-2019, 06:01 AM
rabbit73's Avatar
Quoted: 937 Post(s)
Liked: 415
Well, your Xbox 360 E SHOULD work with your Samsung TV using HDMI, but it doesn't. Have you tried Microsoft support?
https://beta.support.xbox.com/help/x...60e-console-tv
click on Expand all
You will see am HDMI cable which doesn't seem to work for you
You will also see an adapter cable for 3.5mm to composite. It's not HD, but see if it works and call Microsoft support.
Lord Kelvin, 1883
rabbit73 is offline
post #22 of 24 Old 12-22-2019, 07:47 AM
Super Moderator
DrDon's Avatar
Liked: 4559
Pretty sure this is either an issue with the Xbox as Rabbit73 suggests ..or with the television, itself. Given the age of the display and the fact it works with the disc player but not the XBox, there's also a chance it's in the HDMI implementation. Early HDMI rollouts were as flaky as the early USB rollouts. Supposed to be universal but some things worked and some didn't. Microsoft likely didn't test the XBox with displays this old.
Check the XBox on another display using HDMI. If it works on another display but not on the CRT, then it could be an HDMI handshaking issue. The XBox doesn't like what it sees during handshaking and shuts off the HDMI output. If that's the case, you might have to use the component inputs, instead. I see XBox 360 component cables on Amazon and Walmart, but I don't own an XBox so I can't vouch for them. If it works, it's a pretty inexpensive solution.
It's possible a firmware update could also solve your issue. Trouble is, those firmware updates tend to disappear once a device reaches a certain age. I have a firmware update and a special cable for a Samsung SIR T-151 tuner I probably loaned out a dozen times in the last decade because Samsung ended support (and thanks to all the honest AVSers who mailed it back once they were done). I also have three Sony LCD displays I bought for next-to-nothing because they "didn't work." Firmware updates fixed 'em all.
Check your CRT's firmware version if there's a menu that'll display it. Then dig around on the web to see if there's an update. Probably won't be on Samsung's site, anymore, but someone somewhere might have it. Today's smart TVs can do that all by themselves. Sets this old will require a program on a USB stick stuck into that service port.
In the meantime, I'm going to retitle and move this to CRT displays where there's a better chance of someone with this line of displays will see it.
DrDon is offline
post #23 of 24 Old 01-02-2020, 10:56 AM - Thread Starter
Quoted: 41 Post(s)
Liked: 2
I had no idea you could update these old devices but my onkyo 818 never would accept the update from the onkyo site on a flash drive .
post #24 of 24 Old 01-10-2020, 08:03 PM - Thread Starter
Quoted: 41 Post(s)
Liked: 2
How do you upgrade the crt ? A flash drive or something lol never heard of handshake issue but Xbox 360 works on my lcd that’s around same age as the Samsung .
Reply Direct View (single tube) CRT Displays
