Jvc av-34wp84 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-02-2020, 02:18 PM - Thread Starter
Liked: 0
Jvc av-34wp84
Hello, I’m a new member and I have a question about the JVC AV-34WP84. Can it natively handle 720p without up-converting it to 1500i through it’s Component and DVI-D ports?
DJtheAudioandVideophile is offline
post #2 of 5 Old 01-02-2020, 02:25 PM
Ratman's Avatar
Quoted: 2496 Post(s)
Liked: 2317
Typically, most all HD CRT's only display 480p (actually 540p) or 1080i. Although, 480i and 720p material will be deinterlaced/upscaled appropriately for display.
(I have no idea about 1500i)
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 5 Old 01-02-2020, 03:55 PM - Thread Starter
Liked: 0
On JVC site it says the jvc av-34wp84 upscales to 1500i.
I’m just trying to understand if it can show 720p without upscaling it. I’ve read some sites that says it can, and some that says it cannot. Would like to find concrete information about it before I invest in this set.
post #4 of 5 Old 01-02-2020, 05:10 PM
Ratman's Avatar
Liked: 2317
I say it does not.
Good luck.
post #5 of 5 Old 01-02-2020, 11:13 PM - Thread Starter
Liked: 0
Thank you.
Reply Direct View (single tube) CRT Displays
