DLP DMD chip size matter? - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 1 Post By dovercat
  • 2 Post By Frank714
  • 1 Post By sage11x
  • 4 Post By zombie10k
  • 1 Post By Frank714
  • 1 Post By Dave in Green
  • 1 Post By DunMunro
  • 1 Post By sage11x
post #1 of 27 Old 12-23-2009, 10:20 AM - Thread Starter
angel2167882's Avatar
Hey all!
I was just wondering what exactly the DMD chip size means?
For example, my Optoma 1080p features a 0.95" chip, while some others 1080p features 0.65" chip.
Does it means a smaller chip will have every mirror closer to each other, means less SDE and less light loss?
Or is bigger chip are better?
Is that the difference between Dark Chip 1/2/3/4 etc?
And I guess a same technology chip (let say DC2) with 720p will be smaller than a 1080p right?
P.S. What is the sticky warning with "Costco" post? Does it means I can't say that I bought my PJ at Costco for example? Or is it to prevent people posting "Hey look at this PJ at Costco for sale, is it good?" or just to prevent advertising?
angel2167882 is offline
post #2 of 27 Old 12-23-2009, 09:48 PM
gsmollin's Avatar
The larger the DMD, the larger you can project an image before the diffraction limiting effects of the DMD become, er, limiting. Now to take advantage of this you need a commensurate lens and lighting system. For instance, I am using the large Sanyo PJ, see this thread for details: https://www.avsforum.com/avs-vb/showt...887&highlight=
This PJ is diffraction limited by its .95 DMD at 1/2 pixel. The lens is also limited by chromatic abberation at the same level. This PJ can literally project single pixels accurately. Try that with your typical PJ. Anyway, the .95 DMD is the correct size for 1080p, diffraction limited performance. Coupled to the right light engine and lens, its an awesome performer.
The Costco sticky is to prevent the endless pricing posts about what's on sale at Costco this week.
gsmollin is offline
post #3 of 27 Old 12-24-2009, 06:55 AM - Thread Starter
Ok, so with my PJ installed at 12" from a 100" screen, I'm far from the limiting factor I guess then!
Makes sense, when watching closely, I can distinctly see every pixel, as the SDE too!
post #4 of 27 Old 12-24-2009, 09:14 AM
dovercat's Avatar
Quoted: 104 Post(s)
Liked: 55
A small chip size needs a better lens than a larger chip size to produce the same quality image. All things being equal larger chip size is better.
See http://www.videovantage.com/?p=11 for a comparison of image sharpness between 0.65" and 0.95" chips.
The reason for smaller chip sizes is purely commercial they are cheaper to manufacture, you get more per wafer. Unfortunately quality lenses are expensive so the end result is cheaper projectors but with less sharp picture quality, at least if you look very closely at the screen.
The difference between darkchip versions used to be the design of the chip. Amongst the things they have improved are increasing the pixel fill factor with each generation of chip, and increasing the amount the chip tilts and speed it can tilt at. These improvements produce a higher off chip contrast ratio. They have also altered the chip driver technology which has reduced the amount of temporal/spatial dithering a projector needs to uses with a high speed colorwheel.
(1992)B2 Chip 50:1
(1995)HH Chip 250:1
(1997)SRV Chip 400:1
(2000)SRV+SMG 800:1
DarkChip1 >1500:1
(2003)DarkChip2 >2000:1
DarkChip3 >2300:1
New DarkChip4 upto 30% higher contrast than DarkChip3 depending on application
New DarkChip1 ?
Unfortunately they produced multiple versions of the same darkchip and now they have even started producing new chips and calling them DarkChip1 to distinguish them from higher premimum DarkChip4 chips. So it is difficult to tell what individual chip specs are.
DLP rear projection tvs use different versions of chips to front projectors, the chips used by rear projection tvs are cheaper and have one diamond shaped mirror per two image pixels, they rely on wobulation to produce 1080x1920 resolution, while front projector chips have square mirrors, one mirror per pixel, and do not use wobulation.
Frank714 likes this.
dovercat is offline
post #5 of 27 Old 12-24-2009, 01:39 PM
gsmollin's Avatar
The diffraction limit is built into the PJ, and is not a function of your screen size. The screen size gives you the magnification of the DMD, 105 in your case. The diffraction limit is dependent on the pixel size, about 10 microns in this case, and the focal length of the lens. You can look up this topic. Diffraction limiting is seldom discussed around here, but is a pretty hot topic on the microscope, telescope, and photography forums.
gsmollin is offline
post #6 of 27 Old 09-17-2019, 02:23 AM
kokokka's Avatar
Quoted: 29 Post(s)
Liked: 4
Hi!
I don't find nowhere, so a i ask : What size the DLP chip of Benq W1070? 0.65'' os 0.95''?
THX the answer!
kokokka is offline
post #7 of 27 Old 09-17-2019, 02:49 AM
Quoted: 268 Post(s)
Liked: 87
wow! so 10yrs. ago the where using a 0.95" DMD chip? VS. 0.47" now.
XGimi CC, XGimi Z6, UKCSIS, Vmai M200 Pico
Xbox One S, LG SH4
wheelee is online now
post #8 of 27 Old 09-17-2019, 03:35 AM
Frank714's Avatar
Quoted: 969 Post(s)
Liked: 429
Originally Posted by dovercat View Post
DarkChip3 >2300:1
AFAIK the FullHD 1080p DarkChip3 is still state-of-the-art in terms of native contrast / black levels.
IIRC, the large 4K XPR 0.66" DMD (used in first gen 4K DLP projectors and now has a 'comeback' with 3D support)
has a maximum native contrast of around 1,000:1 while the smaller 4K XPR 0.47" DMD only yields a native contrast of around 500:1.
Supposedly the decrease in size plus the XPR pixel shifting has deteriorating effects concerning achievable native contrast.
Optoma has also an entry level of HDR capable front projectors but with only Full HD resolution. I assume these are also using the less expensive 0.47" DMD rather than the 0.65" DarkChip3, so native contrast should be accordingly.
Unless I'm mistaken one 1080p DLP projector that is still available and uses DC3 is the Vivitek H1188 (and a rather good one, I should add) and probably a few BenQ models.
sage11x and jpbonadio like this.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #9 of 27 Old 09-17-2019, 04:52 AM
kokokka's Avatar
Quoted: 29 Post(s)
Liked: 4
I found it earlier (but don't know where), the chip in the W1070 is a 0.62 '' DarkChip DMD. Is this true?
kokokka is offline
post #10 of 27 Old 09-17-2019, 10:46 AM
sage11x's Avatar
Quoted: 2811 Post(s)
Liked: 2834
The pixel shift is a big culprit. BenQ was able to improve native contrast on the .47 XPR DMD (HT3550 / HT5550) by upgrading the lens and actuator to lessen internal reflections. According to them the native performance difference between the .47 and .67 is not all that great with the exception that the .47 sees twice as many shifts. This makes sense considering the actual pitch and tilt of the micro mirrors on the .47 and .67 are identical.
The BenQ HT2050A, HT3050, HT2150ST all use the DC3 .65 as well as the Optoma HD27HDR and the Viewsonic that replaced the 7827... can’t remember the model name now. I think there are more...
jpbonadio likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #11 of 27 Old 09-17-2019, 11:09 AM
zombie10k's Avatar
Quoted: 5422 Post(s)
Liked: 5785
wow resurrecting a 10 year old post nice..!
I still have a number of projectors that use the .95 and the .65 DMD's. yeas ago I swapped in a DC4 .95 DMD into the Planar/Runco projector. it still works great to this day. I keep a few .65 and .95 spares in case any of the DMD's have an issue.
They changed the materials on the newer style DMD's, these must have been pretty expensive to make with the classic ceramic and gold design. apparently some folks harvest old DMD's for $$ gold.
I'd like to see TI create a .95 native UHD DMD for the consumer market.
sage11x, wheelee, Frank714 and 1 others like this.
zombie10k is offline
post #12 of 27 Old 09-17-2019, 01:04 PM
sage11x's Avatar
Liked: 2834
There is a .95” native 4K DMD. But I believe it has the same 5.4 μm pitch and ±17 degree tilt as the smaller .47 and .67 DMDs. These are all part of TI’s new “TRP” pixel architecture. I’m sure the .95” would have better contrast simply owing to NOT having to utilize an actuator (to shift pixels) as well as the corresponding increase in lens size and quality that would accompany such a large imaging chip. In either case— a projector utilizing this chip would likely be really expensive.
I keep coming back to my local IMAX theater. They have one of the IMAX digital projectors which utilizes two 4K light engines that overlap on the same screen. The tech being employed in this monster is DLP but the image has far greater contrast than any DLP I’ve seen for home or commercial use. Clearly there is a way to squeeze more contrast performance from DLP but the question becomes: is there anyway to do that affordably enough or efficiently enough to make sense for the consumer market.
sage11x is offline
post #13 of 27 Old 09-17-2019, 01:15 PM
Quoted: 41 Post(s)
0.47" vs 0.66" DMD contrast
Does the chip size effect contrast as well? the 0.47" XPR models seem to have less contrast than the 0.66" models, but that could just be light source / color wheel implementation...
ccarota is offline
post #14 of 27 Old 09-17-2019, 01:56 PM
AV_Integrated's Avatar
Quoted: 1648 Post(s)
Liked: 1197
Yes the smaller chips have lower contrast than larger chips.
This seems to be because of the light spraying off the edge of the mirrors. 2 million mirrors across .47" vs. .65" and you still have the same edges to deal with between all those mirrors. It creates an issue of scattering light vs. reflected light. With the .47, there is less light reflected and more light scattered compared to the larger chip which has more light being reflected off the mirror, and less being scattered.
It may be an overall issue with DLP that because it doesn't block light, but reflects light, that it just can't reach the black levels of the transmissive technologies.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #15 of 27 Old 09-17-2019, 03:41 PM
airscapes's Avatar
Quoted: 518 Post(s)
Liked: 431
Isn't it about time the Men in Black release a new piece of tech
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #16 of 27 Old 09-17-2019, 04:47 PM
bdht's Avatar
Quoted: 296 Post(s)
Liked: 113
What if the back of the mirrors and the dmd chamber were lined with some kind of protostar ultra black!
bdht is offline
post #17 of 27 Old 09-17-2019, 05:21 PM
airscapes's Avatar
Quoted: 518 Post(s)
Liked: 431
it would catch fire in minutes, it has been tried..
Doug
post #18 of 27 Old 09-17-2019, 05:47 PM
bdht's Avatar
Quoted: 296 Post(s)
Liked: 113
Hah! I know im sorry it was a joke. gotta get that second panel. lasers and irises will have to do until something new comes along. Its a shame because despite lcos' good response(2.5ms btw?) theres still a big difference with dlp(0.25ms?)
bdht is offline
post #19 of 27 Old 09-17-2019, 09:13 PM
airscapes's Avatar
Quoted: 518 Post(s)
Liked: 431
Where it was tried https://www.avsforum.com/forum/24-di...l#post39371730 probable other places as well
Doug
post #20 of 27 Old 09-18-2019, 08:27 AM
Frank714's Avatar
Quoted: 969 Post(s)
Liked: 429
I remember a technical discussion with somebody with close ties to TI many years ago and one of the issues was rather simply that on paper the micromirrors are ideally perfectly flat (for optimal on/off performance) but in reality are rather convex (i.e. curved).
I'd assume that as the mirrors get smaller, it becomes rather difficult to keep them flat. So I'd speculate that the larger the DMD chip (and its mirrors), the 'flatter' the micromirrors will be and the practical performance would be much better in the end.
So DLP DMD chip size probably does matter.
AV_Integrated likes this.
Frank714 is offline
post #21 of 27 Old 09-18-2019, 06:55 PM
Quoted: 268 Post(s)
Liked: 87
..and just saw that the 1080P XPR chip has gotten smaller @ 0.23" DMD size! 960x540 mirrors
http://www.ti.com/product/DLP230NP
Ultra Compact 0.23-Inch (5.95-mm) Diagonal Micromirror Array
  • Displays 1920 × 1080 Pixels On the Screen
  • 5.4 µm Micromirror Pitch
  • 17° Micromirror Tilt (Relative to Flat Surface)
  • Side Illumination for Optimal Efficiency and Optical Engine Size
  • Polarization Independent Aluminum Micromirror Surface
Xbox One S, LG SH4
post #22 of 27 Old 09-20-2019, 08:33 AM
Russell Burrows's Avatar
Quoted: 87 Post(s)
Liked: 30
Talking
The black velvet was a fail.
However black lava glass pluss liquid nitrogen cooled requires serious heat serious heat to melt.
Denon 4k avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount at diy 135 inch screen triple 15 boss build .
Pending buy fourty 6 inch drivers for some new mains new 4k lg hu70la projector 1240 cubic foot ib for 16 fi car audio ib318 v2 subwoofers 4 nx3000 dsp
Russell Burrows is offline
post #23 of 27 Old 09-20-2019, 10:16 AM
bud16415's Avatar
Quoted: 2164 Post(s)
Liked: 1088
IMO TI hit its sweet spot on cost/performance with the .65 1080p chip set. It allowed projector manufactures a platform that with using reasonably priced components to put out the best product at the best price drawing in the greatest number of people into the market. At the end you can buy an RGBRGB 1080p dark chip 3 projector that’s small and user friendly fits into a small room with a large immersive image and handles gaming lags for under 700 bucks. Something that put it into a very attractive price point for a huge number or people, and still does.
Then came 4k HDR a much easier resolution in some way for TV than projectors to meet especially DLP manufactures. TI was most likely battling on two fronts to keep up, the technology, and then building a product that could be fit into projectors and still have an affordable offering at the end. Hitting that sweet spot again seems like it was a taller order.
Bud
bud16415 is offline
post #24 of 27 Old 09-20-2019, 11:06 AM
Dave in Green's Avatar
Quoted: 3844 Post(s)
Liked: 3040
[/LIST]
If 4X shifting a native 1920x1080 chip is "true 4K" then 4X pixel shifting a native 960x540 chip is "true 1080p."
Encourage TI to lower the bar and they will gladly oblige.
Dave in Green is offline
post #25 of 27 Old 09-20-2019, 12:04 PM
Ericglo's Avatar
Quoted: 3663 Post(s)
Liked: 2081
As Darin said in that thread, if you go in the other direction and lower the light output then you can increase on/off contrast.
Having fun playing the new mobile game Volley Village
Ericglo is offline
post #26 of 27 Old 09-20-2019, 12:13 PM
Quoted: 799 Post(s)
Liked: 414
[/LIST]
From the same data sheet:
"8.2 Typical Application
A common application when using DLPC3436 controller with DLP230NP (.23 1080p), a XC7Z020-1CLG484I4493 FPGA, and DLPA2000 PMIC/LED driver is for creating a Pico projector embedded in a handheld product. For example, a Pico projector may be embedded in a smart phone, a tablet, a camera, or camcorder. The FPGA in the Pico projector embedded module typically receives images from a host processor within the product."
sage11x likes this.
DunMunro is offline
post #27 of 27 Old 09-21-2019, 09:21 AM
sage11x's Avatar
Liked: 2834
That thing is going to be strictly for ultra portable applications where existing product is still soldiering on with 480p. We’re talking projectors in mobile phones and pice projectors that fit into the palm of your hand. I doubt we’ll ever see a HT product that features such a solution.
DunMunro likes this.
sage11x is offline
