Optoma HD66 losing focus problem?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-27-2011, 09:15 AM - Thread Starter
icanic's Avatar
Quoted: 12 Post(s)
Hi,
I have problem with optoma HD66, its always losing focus.
I make it in focus and after sometime it just lose it again.
Does anyone know is there any way to make it not to lose focus after some time?
Thank you!!
Sony KDL-55W755C, JVC DLA-RS46U, PS4 PRO, Nintendo Switch, Apple TV3, Jamo AVR-793, Jamo E875 floorstanders, Jamo SUB550, Jamo E8CEN.2, Jamo E8SUR.2
icanic is offline
post #2 of 3 Old 09-26-2011, 03:29 PM
aarons978's Avatar
I have the same problem! You figure anything out?
aarons978 is offline
post #3 of 3 Old 07-25-2013, 07:15 AM
Doublethumbs's Avatar
I had the same issue. I found that by making a rubber loop that fits around the focus ring, and makes contact with the housing; the projector holds focus. I made mine out of .25 inch OD automotive vacuum hose.I know the response is SUPER late. Better late than never.
Doublethumbs is offline
Optoma Hd66 Dlp 3d Ready Home Theater Projector
