BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ - Page 402 - AVS Forum | Home Theater Discussions And Reviews
 3464Likes
post #12031 of 12124 Old 03-30-2018, 02:02 PM
SamF's Avatar
Originally Posted by dazz87 View Post
Lamp went out last night... I think I only got a bit over 2k hours with the original lamp. Have anyone used this lamp?
https://www.amazon.com/gp/product/B0...7DAANA2Z&psc=1
Or should I go with OEM. Benq site has lamp for $199.00 where the amazon one is only $109.... Any suggestions?
When it comes to lamps I’d highly recommended going with the original manufacturer. Off-brand bulbs will work but generally the reviews will say that they're not as bright right from start and they don't last as long. I replaced my W1070 bulb with a BenQ bulb and for me it was worth the premium.
SamF is offline
post #12032 of 12124 Old 03-30-2018, 02:07 PM
SamF's Avatar
Also, I would highly doubt the veracity of many of the reviews of that lamp on Amazon. Some real gems here, lol:
I makes me feel very satisfied with such pleasant purchasing
By Shannonon December 4, 2017
Verified Purchase
At first, I must make confirm that this lamp I received very soon. I makes me feel very satisfied with such pleasant purchasing.
The lamp is working well with my projector and performances its great functioning.
Very happy to share with such great product.
Always believe the OEM one is the best,but I could try the replacement..
By Kim Rodanoon June 6, 2017
I spent much money on purchasing original product cause I always trust they are high qualified.
Couple days ago my bulb blew out,my friend told me that the replacement bulb from this company is reliable,durable
I would choose to purchase one for having a try.
Suggested to others
By Amazon Customer on July 25, 2017
I make sure this is an excellent lamp I had found. I am very interested in researching such kind of product.
I could easily tell from the badness and goodness.
SamF is offline
post #12033 of 12124 Old 03-30-2018, 02:28 PM
mooseehead's Avatar
Quoted: 122 Post(s)
Liked: 26
Verified Purchase
Suggested to others
At $200, do you replace the bulb or get a new projector?
Sent from my SM-G930V using Tapatalk
mooseehead is offline
post #12034 of 12124 Old 03-31-2018, 08:26 PM
tibimakai's Avatar
Quoted: 163 Post(s)
Liked: 48
Those are some chinglish reviews. Most likely, the seller wrote them, via Google translator.
Living Room: Samsung UN65JS8500, Onkyo TX-NR656, Klipsch R-28F, Klipsch RC-62II, Klipsch R-14S, Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290, Onkyo TX-RZ610, Onkyo & Fluance speakers
Garage: Benq HT2050A, Elite Screens 125" motorized screen, Klipsch RP-160M, Klipsch RP-150M, Klipsch RP-450C , 2 x Klipsch CDT-3800 II for Atmos, Klipsch RW10
tibimakai is offline
post #12035 of 12124 Old 04-01-2018, 07:58 AM
Fabricator's Avatar
Quoted: 238 Post(s)
Liked: 137
yeah, that stuff is laughable. and they don't even know it = good for us.
BenQ HT1070 . Da-Lite HP 2.8 119"
ULTIMAX 18-22, 14cf ported, x2. 6000DSP.
XPA-3, PIONEER VSX-01TXH, SWANS 6.1 & C3
Fabricator is offline
post #12036 of 12124 Old 04-03-2018, 01:10 AM
Liked: 1
I've bought my last two bulbs from AliExpress (and there's another on the way so I have a spare - waiting 2-3 months for a bulb when you have none is hell!).
There is the usual crap there but you can buy ones that are identical to the bulb that came with it, and I do mean identical. I made the mistake of getting the crappy copies from Amazon (UK) and after sending back the third one started looking elsewhere.
I don't know if I can name AliExpress sellers here so I won't, but you can tell from the pictures and the reviews that they are the real thing. The one on the way is the full housing, I don't know how I missed that the first two times and bought the bare bulbs :/ Be interesting to see how original the housing is as I've bought "original bulb custom housing" from the UK before and the housing didn't fit (but again the bulb was the real deal).
Anyway, just my 2c.
--Liam.
BattleAxeVR likes this.
liammcn is offline
post #12037 of 12124 Old 04-03-2018, 05:35 AM
JRock3x8's Avatar
Quoted: 1832 Post(s)
Liked: 589
So bare bulb vs bulb kit?
I need to make a decision in the next month whether to replace my 1070 bulb or buy the Optoma 4k UHD51.
Leaning towards the latter but probably will keep the 1070 so will need to replace regardless.
JRock3x8 is offline
post #12038 of 12124 Old 04-03-2018, 11:06 PM
dreamer's Avatar
Quoted: 1494 Post(s)
Liked: 597
If the W1070 is only going to be a backup projector, just get the CTLAMP including module from Amazon for $45. I used two of them and they were fine -- not quite as bright and the first only lasted 2500 hours while the second is still fine and has about 100 hrs so far. My W1070 is now my backup for my HT2050A.
Kirk Ellis
BenQ TK800 VuTec 122" Screen, Harmon Kardon AVR 247
Psycoustic Mark III L&R Towers, Boston Center, Energy Take 5 Surrounds
dreamer is online now
post #12039 of 12124 Old 04-03-2018, 11:47 PM
dazz87's Avatar
Quoted: 83 Post(s)
Liked: 40
My lamp came in today from Benq. I ended up not cheaping out and going with Benq. It was $215.00 including tax here in Cali. My original lamp blow up last week. After installing the new lamp i went to see how many hours i got from the first lamp. End up with only 3822hr. Kinda bum, cause from day one I set my 1070 to eco mode and only got 3800 even tho its rated to get 6000 hours....
dazz87 is offline
post #12040 of 12124 Old 04-04-2018, 09:45 AM
tomtastic's Avatar
Quoted: 1260 Post(s)
Liked: 495
M End up with only 3822hr. Kinda bum, cause from day one I set my 1070 to eco mode and only got 3800 even tho its rated to get 6000 hours....
Only? That's about what I got on original bulb and a 45.00 bulb got me almost there on next bulb.
This line intentionally left blank.
tomtastic is offline
post #12041 of 12124 Old 04-04-2018, 03:08 PM
Ken McPherson's Avatar
Quoted: 254 Post(s)
Liked: 146
I had good luck with this:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ken McPherson is offline
post #12042 of 12124 Old 04-04-2018, 03:54 PM
JRock3x8's Avatar
Liked: 589
Originally Posted by Ken McPherson View Post
that is the exact bulb I have in my saved for later list
still waiting for the warning message and I'm well over 3600 hours
JRock3x8 is offline
post #12043 of 12124 Old 04-04-2018, 03:56 PM
Luis Gabriel Gerena's Avatar
Quoted: 171 Post(s)
Liked: 80
That is pretty awesome! Good to know as I am about to sell my W1070 after 4 years with 800 hours on it. Time to say goodbye but I had a great time with this projector.
Projector: JVC DLA-RS520
Receiver: Onkyo TX-NR3010 Speakers: Rockets RS-760, RSC-200 (Bigfoot), RS-250, ELT525 | Subs: dual HSU VTF-15H and one MFW-15
Luis Gabriel Gerena is offline
post #12044 of 12124 Old 04-04-2018, 03:56 PM
JRock3x8's Avatar
Liked: 589
800 hours holy crap that's practically new.
JRock3x8 is offline
post #12045 of 12124 Old 04-04-2018, 03:59 PM
Quoted: 171 Post(s)
Liked: 80
yeah seriously I didnt realize how little I was using it lately mainly cause I was getting so used to deeper blacks and contrast from other displays that it was affecting my enjoyment of it unfortunately. Plus it was dedicated to movies only so that helped keep the hours low.
post #12046 of 12124 Old 04-19-2018, 07:01 PM
dchabby's Avatar
Quoted: 148 Post(s)
Liked: 96
so my projector has been getting a red light lately and shutting down. I can usually turn it back on after a short break and it will work but it is becoming more frequent.
The fan is very noisy lately as well.
Is this red light/shut down a sign of a bad fan or that the bulb is going bad/overheating ?
Im kinda leaning toward the fan since it is very noisy when it shuts down so can you just replace it ? or maybe add an external fan to blow cooler air into the projector ?
I have had the projector for about 5 years so i know the bulb is getting old so i guess it could be that too, not sure.
dchabby is offline
post #12047 of 12124 Old 04-19-2018, 09:57 PM
Liked: 0
Someone please help, my projector is no longer giving me an image. Im trying to play my ps4 and it just says "source detect" and nothing happens! Ive had it 1 year and 1 month so of course its just out of warranty!!! Grrrr... Never had an issue with it, havent used it in a month or so and then i try to play and it doesnt work! Tried multiple hdmi cables, both hdmi ports, my ps4 and switch which both have worked flawlessly. Im at a loss
castlemadeofsand is offline
post #12048 of 12124 Old 04-20-2018, 10:42 AM
descalabro's Avatar
Quoted: 416 Post(s)
Liked: 158
Hi,
Have you tried an input other than HDMI?
descalabro is offline
post #12049 of 12124 Old 04-20-2018, 10:47 AM
descalabro's Avatar
Quoted: 416 Post(s)
Liked: 158
Which light is red? Is it 'power', 'lamp' or 'temp'?
If the fan is noisy then it's probably having a hard time spinning, and not spinning within the necessary speed interval (+/- 20% of its programmed speed), so it would probably be worth to clean or, if it's really faulty, replace that fan.
post #12050 of 12124 Old 04-20-2018, 11:37 AM
dchabby's Avatar
Quoted: 148 Post(s)
Liked: 96
Thanks - I didn't realize until after I quoted that it could have been more than 1 light so I will have to check next time it goes on.
Do we know what size fan is inside and if it easy to replace ?
dchabby is offline
post #12051 of 12124 Old 04-21-2018, 05:15 AM
descalabro's Avatar
Quoted: 416 Post(s)
Liked: 158
It usually goes by the model, not by the size. You have to search for that fan by the model of the projector or of the actual fan. I would first try to clean it with compressed air, and only then replace it if necessary. Removing fans is relatively simple if you're technically inclined; don't try it if you're not.
Here's the service manual, which should give you some guidance:
https://www.scribd.com/doc/208363905...Service-Manual
post #12052 of 12124 Old 04-26-2018, 10:52 AM
dchabby's Avatar
Quoted: 148 Post(s)
Liked: 96
thanks I did manage to get most of the fans cleaned out and it seems to be working a lot better now.
one thing though - I did use some compressed air in the body of the projector and now I have spots all over the screen which I assume is dust that got into the lens or color wheel.
Is there a good/easy way of getting this cleaned up ?
dchabby is offline
post #12053 of 12124 Old 04-28-2018, 02:43 AM
Liked: 2
To change the color wheel on the W1070 I need to remove the two screws facing the back of the box on the housing, correct? So, use a either right angle screw driver or take the circuit board off?
I've found a replacement on ebay, based on the part # I read on the wiring (QISDA-102418672).
Does anyone know if other color wheels fit and if so which ones?
The used ebay item is $49 and free ship. Has anyone priced these from BenQ in Chino, CA?
Any help appreciated.
DansWife is offline
post #12054 of 12124 Old 04-28-2018, 09:56 AM
Quoted: 519 Post(s)
Liked: 293
It's not the colour wheel the problem but the DMD now has flecks of dust on it. The optical cavity isn't actually sealed on these projectors so compressed air cans should be avoided at all costs. Tip: never hold the can upside down or fire it for too long, because liquid comes out and that is a nightmare to remove. You can first try opening up the exhaust port on the optical assembly (a small screw holding a flap to the side of the lens shift screw), and fire a couple quick blasts in there, it might work well enough.
I did the same thing and had to wipe the DMD by opening up the entire projector. It is a royal pain, trust me, because you won't know if there are new flecks on the DMD until after you close it all up again and fire it up, which can take a while. All told, it took me about a dozen times before I got it perfect with no splotches or smears on the projected image. Beware, if you walk down this path, madness and frustration awaits you. Abandon all hope ye who enter here.
You could instead try sending it in the BenQ to do it but there's no guarantee they will, even if it's under warranty. They might.
dchabby likes this.
BattleAxeVR is offline
post #12055 of 12124 Old 04-28-2018, 08:13 PM
dchabby's Avatar
Quoted: 148 Post(s)
Liked: 96
BattleAxeVR - I cant thank you enough for this post !
I decided to open up my projector again and followed the owners manual as to how to take it apart properly.
But i wouldnt have know what to look for and what to do if you didnt mention the DMD.
Found the DMD with the help of the manual and wiped it clean with a cotton swab. Swabbed what i guess is the mirrors as well and also cleaned up the blower fan which i didnt get to last time.
Everything is working great now and no more spots !!
Thanks again for the post !!
dchabby is offline
post #12056 of 12124 Old 04-28-2018, 08:36 PM
Quoted: 519 Post(s)
Liked: 293
Glad to be of service my good man. Enjoy.
post #12057 of 12124 Old 04-29-2018, 06:56 AM
Fabricator's Avatar
Quoted: 238 Post(s)
Liked: 137
i am suprised there is no filter mod talk.
post #12058 of 12124 Old 05-01-2018, 03:18 AM
Liked: 0
Hi guys, I just registered because i'm in serious need of help & I hope you guys can provide it..
Here goes:
I own a W1070+ Benq beamer and everything has been working fine for 2 years.
Just yesterday my HDMI switch broke down, so I needed to plug in everything manually. Now here's the thing: only some of my devices are displaying.
My laptop & Playstation 4 display nothing , but the HDMI signal does light up green.
My TV box's signal switches on & off every 2 seconds.
My Raspberry Pi is the only thing that works perfectly.
I've tried many different HDMI cables (long & short) , I've tried factory resetten the beamer, i've tried unplugging the beamer for 10minutes (and also the other devices).
Now i'm out of ideas.. The only thing I found on the internet is that maybe my hdmi switch was responsible for ignoring the HDCP signal which is why everything worked ? I don't know..
Sigh..
Osis1984 is offline
post #12059 of 12124 Old 05-01-2018, 11:45 PM
Liked: 0
--Liam.
Can you maybe PM me which which bulb you bought from ali express or can you point me in the right direction? My current W1070 bulp is at over 6000 hours at the moment and i notice the picture getting weaker. I think i need the full housing.
Thanks in advance
Nyrad2k is offline
post #12060 of 12124 Old 05-02-2018, 02:24 AM
dreamer's Avatar
Liked: 597
Here goes:
Sigh..
My Benq W1070 was bad about locking on to weak HDMI signals. I finally had to bypass my AV Receiver and buy a separate HDMI Switch which put out a stronger signal. I don't think your switch was stripping the HDCP, it just worked because it put out a stronger signal.
Kirk Ellis
benq w1070 , Benq W1070 1080p 3d Projector , w1070
