Can the W1070 compete with the W7000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-08-2013, 01:45 PM - Thread Starter
jamieuk147's Avatar
Quoted: 76 Post(s)
For Sharpness and 3D as well as being good for gaming?
jamieuk147 is offline
post #2 of 6 Old 01-08-2013, 10:27 PM
jnabq's Avatar
Liked: 43
The 7000 would have better blacks, I haven't seen any lag reports on the W1070, with some tests showing the W7000 being, around 35ms. 2 frames at 60Hz refresh rate?
jnabq is offline
post #3 of 6 Old 01-08-2013, 11:11 PM
Elix's Avatar
Quoted: 253 Post(s)
Liked: 106
Only by using the dynamic iris (which is largely unusable). W1070's native contrast is higher. W1070 lacks frame interpolation and placement flexibility. W7000 has a DC2 DLP chip, W1070 has DC3. I haven't seen both projectors side-by-side, but judging by everything I know W1070 is a better value, imo.
Elix is offline
post #4 of 6 Old 01-09-2013, 05:13 AM
talon95's Avatar
Quoted: 332 Post(s)
Liked: 186
It is not largely unusable. In dark scenes (which is where black level counts the most), it is very effective. There may be better iris implementations, but it works quite well when it counts the most.
talon95 is offline
post #5 of 6 Old 01-09-2013, 06:15 AM
man4mopar's Avatar
Ranged 0-40ms, Averaged 20ms per here http://www.projectorreviews.com/game-projector-blog/review-benq-w1070.html
man4mopar is offline
post #6 of 6 Old 01-09-2013, 06:36 AM
talon95's Avatar
Quoted: 332 Post(s)
Liked: 186
I do think the W1070 would be a good choice for gaming and 3D though from what I've read (I have the W6K). Otherwise the biggest advantage of the W7000 is placement flexibility. It has much better lens shift and a longer zoom range. Just depends on the room you're putting it in whether this is an issue or not.
talon95 is offline
Benq W1070 1080p 3d Projector , Benq W7000 Home Projection System
