Just got the HD25-LV and found out that the brightness drops significantly in 3D mode. Plus I have massive crosstalk in the green channel. I'll try a full reset to try to get rid of that but the brightness is an issue.
A call to Optoma and they confirm that the brightness will drop in 3D but will be brighter in 2D. So what's the point of buying a brighter 3D projector if it doesn't use the extra brightness for 3D?
They also said they know nothing about this PJ since it is so new and had no idea about the crosstalk.
Another issue is when you go to adjust contrast or brightness, the displayed sliders are so bright that they interfere with the adjustment, especially when using a calibration disk.
Also in 3D the lamp does not brighten, you have to go into the lamp menu to set it to bright then back into it to return to eco mode for 2d viewing.
BrilliantColor drastically changes the white balance.
On the plus side, it doesn't clip the primaries like my HD33.
td
td
