Infocus X1 HDMI??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-29-2013, 01:37 PM - Thread Starter
ser182's Avatar
I have a Infocus X1 in my garage and I upgraded my dish network boxes and the only have HDMI. Can I just use a VGA to HDMI Connector? This will not be for bluray just For dishnetwork. Thanks.
Xbox live- SER 182
Mix Cloud
http://www.mixcloud.com/Ser182/
ser182 is offline
post #2 of 7 Old 05-29-2013, 06:44 PM
Verge2's Avatar
Quoted: 915 Post(s)
Liked: 244
Hdmi to VGA converter will cost as much as an older projector with dvi input.
They don't output composite?
Verge2 is offline
post #3 of 7 Old 05-30-2013, 09:32 AM - Thread Starter
ser182's Avatar
Nope! they have video but not composite. This is the new hopper by Dish. Love my X1 because it still shows like i first bought it ten years ago. Which still amazes me. So i would need a converter. I was hoping to keep my X1 but now i might have to shop for cheap replacement. Thanks
Xbox live- SER 182
Mix Cloud
ser182 is offline
post #4 of 7 Old 05-30-2013, 06:09 PM
Verge2's Avatar
Quoted: 915 Post(s)
Liked: 244
That's composite, why not use it? It's only a 480p projector.
Verge2 is offline
post #5 of 7 Old 05-30-2013, 07:55 PM
Jim McC's Avatar
Quoted: 337 Post(s)
Liked: 107
I used to have the X1. The sat. receiver only has HDMI? No component inputs(red, green, blue)?
Jim McC is offline
post #6 of 7 Old 05-30-2013, 08:18 PM
DragonSixGolf's Avatar
Liked: 26
you mean outputs? yeah, it should.
This might not be a problem you want to work too hard to solve.. " oops sorry honey, guess this new box needs a new projector to connect to" But even if it works... a 10yr non-hdtv projector with a 480 signal? iick. Op seems happy, but with acer h5360 720p and H6510bd for 400 and 630.. it seems a shame not to send that HD signal to a projector that make it look fantastic. OP sure got his money out of the X1.. may be time to put her down.
I don't like "let me spend your money" posts, but in this case i couldn't help it.
DragonSixGolf is offline
post #7 of 7 Old 07-17-2013, 09:40 PM
Cyrano's Avatar
Liked: 91
I have just connected my old X1 to a spare Bluray player via a Component to VGA adapter and the results are pretty amazing. No jaggies. Very nice PQ. Get one at Amazon. In Focus Component to Vesa Adapter Cable (SP-VESA-ADPT-R) for about $20.
A surprisingly sharp picture when fed 1080i.
If the unit you have has only a video (Composite) output the Faroudja deinterlacer in the X1 should still produce a pleasant picture.
Cyrano is offline
Infocus X1 Video Projector , Acer H5360 3d Dlp Projector , Acer H6510bd Dlp 3d Projector
