AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Digital Projectors - Under $3,000 USD MSRP (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/)
-   -   Small / Mini / Pico Projector for traveling on a Plane (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/1475884-small-mini-pico-projector-traveling-plane.html)
rush2049 06-04-2013 10:18 PM
20 Attachment(s)
So I am on a quest to buy a projector that is first of all small, and second light. It will be an accompaniment to the portable desktop PC I am building.
So requirements / desires are:
Resolution:
1080p @ 60hz
or
720p @ 120hz
Weight:
less than 5 pounds
size:
as small as possible, if its small enough I would like to put it in a laptop bag
Lamp type:
Not a bulb, because of the amount of vibration/handling that will happen.
I know these are kind of odd requirements, but I travel for work so much that I miss having a powerful computer/movie player for blurays and gaming.
Sooooo, anyone know of stuff that somewhat meets these requirements? I've been looking, but nothing somewhat small meets the resolution requirements and the lamp type.....
I am concerned that a bulb would break with the amount of vibration a plane/carrying around would do to it.
edit
I am also one of the types that like to buy the best I can afford. So if there are a lot that meets these requirements, whats the best that you would recommend?
Amber Ale 06-05-2013 01:23 AM
Acer K750 1080P HD 1920x1080 1500 Lumens DLP LED
Read acer k750 topic and this one.
rush2049 06-05-2013 05:33 AM
20 Attachment(s)
Thank you Amber Ale, I did not come across that in my scouring.
Are there any other options? While I like the K750 it is a little on the heavy side and might put me over my weight limit.
fido dido 06-05-2013 05:49 AM
what about any of the lg led projectors
rush2049 06-05-2013 06:47 AM
20 Attachment(s)
The PA75U does look promising....
is there a higher model that I am missing?
Anything similar?
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
