AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Digital Projectors - Under $3,000 USD MSRP (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/)
-   -   Need help with best projector for my use (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/1482589-need-help-best-projector-my-use.html)
Drew Murphy 07-21-2013 12:11 PM
So i got the benq 1070 and returned it becuase it was not goood for high fps gmaming, so now im looking at the epson 3020 and the mitsihish hc400 the main uses will be watching nhl hockey and playing highfps xbox games so im not sure which projector would be best for this thanks!!
ElectronicTonic 07-21-2013 12:22 PM
If you plan on gaming a lot, the 3020 has pretty bad input lag.
Drew Murphy 07-21-2013 12:31 PM
i have read that but i am now unable to find a projector that will be good for that. now i dont have to game on it i also have a tv but id like to be able to game on it
ElectronicTonic 07-21-2013 01:29 PM
Yeah, I have a 5010, which has similar input lag. I game on it a bit, but mainly game on my monitors.
In your original question, what was your issue with the BenQ, frame rate issues? I've heard it's pretty good for gaming.
Drew Murphy 07-21-2013 01:52 PM
the benq had the RBE so i sent it back and like the epson but i think i could alwasy get it and if its not good for games then make it just for tv and movies...
aohus 07-21-2013 02:04 PM
using a projector itself for high fps gaming is a bad idea....
you need a monitor that gives low input lag. also, fps gaming on a big screen is not optimal imo.
Sonyad 07-21-2013 02:12 PM
Here's a review of the gaming capabilities of the Acer H6510 http://www.projectorreviews.com/game-projector-blog/review-acer-h6510bd.html. But if you have a problem with dlp rainbows, it might not be a consideration for you.
Seegs108 07-21-2013 04:51 PM
One of the fastest I've seen is the Optoma HD25 which is around 17ms lag time. That's fantastic for a projector.
MississippiMan 07-21-2013 07:28 PM
The Epson 8350 has the same measured ultra fast Lag as the HD25, and being a LCD obviously does not have any worries as far as RBE.
It also has:
  • No Image Off Set
  • Horizontal and Vertical Lens shift
  • A MUCH more versatile Throw / Focal Length... a full 5x longer in fact (13'). The HD25? just a tiny bit over 2'
The 3rd point above means you can place it much closer to the Screen. and with it's prodigious Vertical Lens shift capability, it can be mounted very high. High up & Close + Vertical Shift equate to being able to stand much closer to the Screen when engaging in FPS gaming. And you KNOW what that means.... cool.gif
Drew Murphy 07-22-2013 07:45 AM
It also has:
  • No Image Off Set
So your saying that the epson my be better? as ii said if its not good for gaamming ill just use it for movies and tv.... but i like that its lcd though so RBE wont affect anyone at all
MississippiMan 07-23-2013 03:00 PM
Read it all again...pretty straightforward.
Yes...it would be better in every respect. No contest what with all your wants and needs being considered.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
