Sanyo PLV-Z4 Warning light and lamp replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-31-2013, 07:39 PM - Thread Starter
spring1283's Avatar
Turned our projector on and door opened and startup began but lamp didn't light up and warning light and lamp replacement light came on.
Purchased a new genuine lamp and changed it in machine. But same thing still happens.
Any suggestions? Is there a reset procedure using buttons on unit that can override? Filters have all been cleaned.
spring1283 is offline
post #2 of 2 Old 08-01-2013, 07:39 AM
Mr.G's Avatar
Quoted: 1328 Post(s)
Liked: 1722
Are you the original projector owner? Are you sure it's a OEM lamp assembly not just an OEM bulb?
Try reseating the lamp assembly, take it out and reinstall.
Look through this thread:
https://www.avsforum.com/t/835878/help-sanyo-pl-z4-trouble
-G
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
Sanyo Plv Z4
