Decent Projector For Gaming Under ~800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2013, 05:47 AM - Thread Starter
ronzem's Avatar
Hello
Im looking for a fairly cheap projector to use mainly for gaming, both from PC and Xbox.
My first choice would be Benq W1070 but that one is too expensive for me here in Sweden, I might find a used one tho..
Anyway if im looking to buying a new projector, what would be the best choice?
720p
~3meters
Im interested in Benq W700+, is it a good choice?
Or maybe Epson TW480/550?
There's also this new Optoma H100 but I find no reviews
ronzem is offline
post #2 of 3 Old 08-13-2013, 07:41 AM
niknod's Avatar
You might also consider the Viewsonic PJD7820HD. It is bright and has very low lag times and is cheaper than the W1070
its 1080p, as well
Review here:
http://www.projectorreviews.com/viewsonic/pjd7820hd/index.php
If you only care about 720p, you might look at the Optoma GT750 or GT720 - both carry low/zero lag times and were designed specifically for gaming. They're a year or two old so you should be able to find one pretty cheap.
niknod is offline
post #3 of 3 Old 08-13-2013, 12:14 PM
nxsfan's Avatar
Quoted: 24 Post(s)
I have the H5360 (720p120) and the ViewSonic PJD7820HD (1080p60). Both are good gaming projectors. I tried 3D gaming on the H5360 and it was pretty incredible (esp Trine 2) but it's not something I would do frequently (I'd imagine the PJD7820HD is even better). I'd be happy to answer any questions.
nxsfan is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Epson Eh Tw550 3d Lcd Projector , Viewsonic Pjd7820hd Full Hd 1080p Projector , Optoma Gt750 Projector , Optoma 3d Game Time Projector For Wii Playstation And Xbox Gt720 , Acer H5360 3d Dlp Projector
