Panny PT AX-100u beats PT-AR100U in brightness ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-17-2013, 08:53 AM - Thread Starter
Ace55's Avatar
I'm about to replace an old PT-AX100u with the new PT-AR100U in a totally dark theater. The mount is 16' away from a fixed Carada 108" screen. I was shocked to see that using Projector Central's calculator for these specs, the old AX100 was actually brighter "out of the box" than the new AR100 will be. Am I missing something here ??????
Ace55 is offline
post #2 of 3 Old 10-17-2013, 10:29 AM
Mr.G's Avatar
Quoted: 1328 Post(s)
Liked: 1725
If you are using the Projector Central calculator there is likely a problem.
Use the Panasonic calculator.
http://panasonic.net/avc/projector/calculator/html/cal_menu.html
Go Wide Aspect. Choose Home Cinema Projector. Then PT-AR100U. Input diagonal screen size and press calculate for lux.
108" screen yields 871 lux.
Go back to original menu and find Previous Models drop-down, scroll down PT-AX100.
108" screen yields 622 lux.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #3 of 3 Old 10-17-2013, 03:48 PM - Thread Starter
Ace55's Avatar
Thanks very much....that's more like it. At Projector Central the calculator gives the old AX100 - 21FL and the new AR100 only 18FL at 16 feet....strange.
Ace55 is offline
Panasonic Pt Ax100u Home Cinema Projector , Panasonic Pt Ar100u Lcd Projector
