Help w/Throw Distance Vivitek D950HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-28-2013, 03:32 PM - Thread Starter
JNasty's Avatar
I have a chance to buy the Vivitek D950HD for under $600 however I'm new to projectors and I'm concerned about the throw distance. I've been to the throw distance calculator on projector central but I need it explained to me in basic terms.
Basically, I have a room 22 x16. I am wanting to put my projector mount in the back of the room roughly 18 feet from where I plan on putting my screen. My screen (motorized) will cover 2 60" tvs already mounted. Will the mounted distance cover a 120in or bigger screen, sufficiently?
Also there is a ceiling mounted dome light that hangs about 6inch, will that need to be removed?
I really wanted a bargain 3d (the Acer 6510BD) projector but this deal is too good to pass up.
JNasty is offline
post #2 of 2 Old 10-28-2013, 04:23 PM
kevivoe's Avatar
The projector will do a 120" diagonal from 14 feet to 16 feet 9 inches. From 18 feet you will get a 76"x135" image (155 inch diagonal) with the zoom of that projector.
use www projector people dot com and "Projector Calculator" on the right side.
kevivoe is offline
Vivitek D950hd 3000 Lumen 1080p Office And Home Theater Projector
