Owners of MITSUBISHI HC7900DW: Do you find this projector "Dim"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2013, 03:41 PM - Thread Starter
badshah2000's Avatar
What is your take on every reviewer's comments that MITSUBISHI HC7900DW is very "dim" compared to other modern projectors? If I were to consider it for use with my 120" 1.2gain screen in light controlled room, what would be your advice? I don't like blindingly bright picture but still I would not want it to be such that I find it starving for more light. Any and all comments would be appreciated.
THANKS!
badshah2000 is offline
post #2 of 5 Old 11-14-2013, 04:13 AM
kandyman's Avatar
Bought mine two weeks ago through groupon deal amazing picture,projector is in a light controlled bat cave.black ceiling and walls and dark carpet just like when you go out to a movie,how many movie theaters have you been too that have light colored ceilings and walls
Wife was ok with making everything black:)
kandyman is offline
post #3 of 5 Old 11-14-2013, 06:42 AM
whitecamaross's Avatar
Quoted: 18 Post(s)
CAN u ACTUALLY USE IT WITH WHITE WALLS?
whitecamaross is offline
post #4 of 5 Old 11-14-2013, 07:09 AM
nirvana_av's Avatar
I recently bought this projector to replace a nearly 10-year old InFocus 7205. With a new lamp, the HC7900DW is considerably brighter than the 7205 with over 1500 hours on its lamp. My home theater has white walls and ceiling (dark gray screen wall) and has complete light control. This projector is more than bright enough for 2D viewing, but then I'm not into 3D and don't need or want 50+ ft-lamberts of brightness.
nirvana_av is online now
post #5 of 5 Old 11-22-2013, 10:52 AM
crddop's Avatar
I wouldn't say dim. I use it fine with lights on. but I use an 85" area not 120
crddop is offline
Mitsubishi Hc7900dw Home Theater 3d Projector
