LG PA75U Audio out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-16-2013, 06:33 PM - Thread Starter
reloadingdata7's Avatar
Hello,
I'm a newbie and might sound this question dumb and any suggestions are appreciated.
- How can I get the audio out to a receiver from my LG PA75U projector? I know I can get the sound of my dvd player via receiver, but only the issue is getting audio out while watching a TV with a built in tuner.
Is the audio out only 3.5mm audio jack?
And do I get true 5.1 sound through 3.5mm jack? As I got yamaha HTR 3063 5.1 AV receiver.
Any suggestions or comments are highly appreciated.
Thank you
reloadingdata7 is offline
post #2 of 4 Old 11-18-2013, 08:29 PM
HTCrazy's Avatar
I don't think the PA70G has hdmi audio return - tho I could be wrong. If that's the case, you're left with the 3.5 jack to go to your receiver. Then you'd have to use NEO or some other simulated 5.1 mode on your receiver to get surround sound.
Or you could invest in an OPPO and have one hdmi to your projector and another to your receiver. It expensive but it also does crazy good things to the video quality as well on the PA70G.
HTCrazy is offline
post #3 of 4 Old 01-08-2014, 09:03 AM
morphwvu's Avatar
Originally Posted by reloadingdata7 View Post
Hello,
Thank you
Hey there.. I'm in the same boat. Just purchased a receiver last night and was wondering how the sound setup would be with this projector. Do you have your dvd player connected via HDMI to the receiver and then have a HDMI cable out from the receiver to the projector? If so do you get 5.1 surround sound? I plan on using only components hooked up via my receiver and not using any apps or tuner built in the projector. So I assume if your dvd player is working fine in terms of sound I shouldn't have any problems with my cable box/ xbox etc. Thanks for your input
morphwvu is offline
post #4 of 4 Old 01-08-2014, 10:37 AM
Verge2's Avatar
Quoted: 915 Post(s)
Liked: 244
Yes
Yes
Yea
Verge2 is offline
Lg Pa75u Dlp Home Theater Projector
