Mitsubishi HC7900DW Owners Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 49 Old 11-19-2013, 04:56 PM
jibber11's Avatar
Oh, that's not good.....
jibber11 is offline
post #32 of 49 Old 11-19-2013, 05:28 PM
fredwi's Avatar
fredwi is offline
post #33 of 49 Old 11-20-2013, 06:00 AM
nikonf5's Avatar
Originally Posted by postgoodinfoit View Post
No everything are great the only probleme i have sometime the projector stop by himself after 1 hour i dont know that is wrong.
Its probably overheating because of something physical to do with the way its currently setup.
You might want to check the end of the manual to see if the lights on the top panel are used to indicate any issues so if and when it happens again, you can know for sure.
Be warned though: If you continue to use it in its current state, you are putting a lot of stress on the internal components which will shorten the pj's life.
nikonf5 is offline
post #34 of 49 Old 11-20-2013, 01:50 PM
fredwi's Avatar
Be warned though: If you continue to use it in its current state, you are putting a lot of stress on the internal scomponents which will shorten the pj's life.
I just put a fan and this should work now,thank you.
fredwi is offline
post #35 of 49 Old 11-20-2013, 01:59 PM
jibber11's Avatar
A fan?
You shouldn't have to do that
Did you call support?
That doesn't seem right
fredwi likes this.
jibber11 is offline
post #36 of 49 Old 11-20-2013, 02:42 PM
fredwi's Avatar
A fan?
Not yet i just want to be sure i come from the heat issue.
fredwi is offline
post #37 of 49 Old 11-20-2013, 03:58 PM
crddop's Avatar
call support asap. don't risk further damage.
crddop is offline
post #38 of 49 Old 11-20-2013, 07:35 PM
fredwi's Avatar
[q
uote name="crddop" url="/t/1500154/mitsubishi-hc7900dw-owners-thread/30#post_23975466"]call support asap. don't risk further damage.[/quote]
I watched the conjuring very good movie and no probleme.
crddop likes this.
fredwi is offline
post #39 of 49 Old 11-20-2013, 07:40 PM
crddop's Avatar
just got mine, and did Mike's calibration from projector reviews. great image. I'm gonna do a review this weekend with photos and videos. but I am trying to enable the interpolation but it is greyed out, anyone have any thoughts?
crddop is offline
post #40 of 49 Old 11-21-2013, 07:19 AM
nirvana_av's Avatar
Do you have a signal going to the PJ? Some menu items aren't adjustable util it has an input.
nirvana_av is online now
post #41 of 49 Old 11-21-2013, 07:23 AM
crddop's Avatar
yes, hdmi from fios(1080i) I tried the 720p setting from the fios box , same thing.
crddop is offline
post #42 of 49 Old 11-21-2013, 05:59 PM
crddop's Avatar
crddop is offline
post #43 of 49 Old 11-21-2013, 06:02 PM
crddop's Avatar
crddop is offline
post #44 of 49 Old 11-22-2013, 02:05 PM
nikonf5's Avatar
IIRC during my research on this model last year, I believe that option is only available during 1080p/24 playback.
A restriction [whether similar or not] also applies to the 2D-3D conversion.
nikonf5 is offline
post #45 of 49 Old 11-22-2013, 02:09 PM
crddop's Avatar
I got it to work with composite cables. still doesn't with hdmi.
crddop is offline
post #46 of 49 Old 11-22-2013, 02:11 PM
crddop's Avatar
I got it to work with componant, But not HDMI.
crddop is offline
post #47 of 49 Old 11-22-2013, 04:36 PM - Thread Starter
badshah2000's Avatar
I ended up cancelling my HC7900DW order from B&H and bought an HC5 instead. Haven't experienced it yet but from the reviews and other feedback, it should be a decent jump from HC7900--although HC7900 is not bad at all in its own right.
The 3D emitter that I bought for HC7900 will apparently work with HC5 as well so I kept that as I had gotten a really price on that one.
Enjoy your HC7900DW!!!!
badshah2000 is offline
post #48 of 49 Old 11-26-2013, 09:06 PM
StevenC56's Avatar
Quoted: 564 Post(s)
Liked: 201
So how's your new HC5 and does that 3D emitter in fack work with the 7900, 8000, and HC5?
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #49 of 49 Old 12-18-2013, 05:07 PM
ramkum1001's Avatar
if anyone is interested in buying and having BOA card, use it they have 15% returns; so price drops to around ~$800 (999-50-50-15%)
ramkum1001 is offline
Mitsubishi Hc7900dw Home Theater 3d Projector
