Epson 5010 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-21-2013, 07:47 AM - Thread Starter
Noxdowne's Avatar
Just a quick question please.
Can an Epson 5010 project a 150" picture at 15' of throw?
I am replacing my 5010 with a 5030ub in my theatre room and thinking the 5010 could be used in another part of the house.
Thank you!
Jeff
Whether you think you can or think you can't...you're correct!
Henry Ford
Noxdowne is offline
post #2 of 3 Old 11-21-2013, 07:51 AM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
According to the Projector Calculator @ http://www.projectorcentral.com/Epson-PowerLite_Home_Cinema_5010-projection-calculator-pro.htm it technically CAN do that, though you'd have to be at one of the extreme ends of the lens. Also, you're looking at 17fL for the image thrown from it, so the other part of the house has to have little to no ambient light.
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #3 of 3 Old 11-21-2013, 01:42 PM - Thread Starter
Noxdowne's Avatar
Perfect. This is why this forum is amazing.
Thank you very much!
Jeff
Henry Ford
Noxdowne is offline
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson 5030ub 2d 3d 1080p 3lcd Projector
