My new Benq w1500 just arrived - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 12-11-2013, 08:44 AM - Thread Starter
bem1's Avatar
What an awesome little projector!  100x better than my replacement Sharp Vision xv-z10000.  Brightness is perfect as are the colors.  Have not tried the wireless hdmi yet or 3d.
Let me know if I can answer anyone's questions about this projector.
-Blake
bem1 is offline
post #2 of 20 Old 12-11-2013, 10:12 AM
RTK
RTK's Avatar
Quoted: 117 Post(s)
Since it doesn't sound like you need WHDMI, what was your reasoning to get the W1500 over the W1070?
RTK is offline
post #3 of 20 Old 12-11-2013, 11:36 AM - Thread Starter
bem1's Avatar
Slightly higher brightness
Wireless hdmi for future use
Frame Interpolation
2D to 3D Conversion for future use
Better contrast
Better color
bem1 is offline
post #4 of 20 Old 12-11-2013, 12:17 PM
PrimeTime's Avatar
Quoted: 806 Post(s)
Liked: 504
Not many owner reports on this yet. I have two different locations I'm reviewing which have different mounting distance requirements, so this unit's extended zoom range is of interest to me.
There have been mixed opinions on how solid the WHDMI is. Your experience with it would be good to know. I could use it for placement in an adjacent room and project through a window for silent operation, if it is reliable.
Also... How do you like its Frame Interpolation? How's the fan noise?
PrimeTime is offline
post #5 of 20 Old 12-11-2013, 12:25 PM - Thread Starter
bem1's Avatar
Based on the paperwork that came with the projector, it's Max distance for a 100 inch diag screen was 150 inches.  This is where I placed mine.  It's also roughly 15 inches from the ceiling.  I can take photos if anyone is interested.
As far as the fan noise, it's whisper quiet....now this is based on my old xv-z10000, which was VERY loud.
I'll report back on the wireless HDMI.  Going to attach it to my Microsoft Surface and see how it behaves.
For the frame interpolation, I am still messing with the settings to see what is optimal for movies, games, etc.
I think I may have an expert come over and help me tune it properly.....  I've got an Xbox One, and it has a pretty good Display tuning wizard..
bem1 is offline
post #6 of 20 Old 12-11-2013, 03:18 PM
PrimeTime's Avatar
Quoted: 806 Post(s)
Liked: 504
One thing I like to do with Frame Interpolation displays is tune them to Turner Classic Movies and watch old Forties black & white movies (Bogart, etc). The effect is a little erie, I admit, but it gives them a modern feel that I find appealing. And adding an extra layer of smooth to the already-fluid Fred Astaire dance sequences looks "too real" for belief.
(However... to an X-Boxer, probably a little out of time for you guys...)
post #7 of 20 Old 12-11-2013, 09:01 PM
thegarr's Avatar
You mentioned you have an xbox one. How far can the kinect see you still? Im hopeing to get both the xbox and w1500 for christmas but was worried about the projecting distance and casting shadows with the kinect smile.gif
thegarr is offline
post #8 of 20 Old 12-11-2013, 09:40 PM - Thread Starter
bem1's Avatar
Well, unfortunately my Kinect is on the back left hand side of my media room because the cable is not long enough to reach to the front.  I've been voicing my opinion on an extension cable way before XB1 came out.  My hope is that either Monoprice or Nyko will create one soon.  I need at least 20 ft more.
I do still have my 360 hooked up, so I could test Kinect v1 if you want.
BTW, if anyone is interested, I've uploaded the W1500 User Manual to my skydrive folder here:
https://skydrive.live.com/redir?resid=48E860CA7D4B7C93!5507&authkey=!APOdq_qkd1zuLAU&ithint=file%2c.pdf
bem1 is offline
post #9 of 20 Old 12-11-2013, 10:32 PM
thegarr's Avatar
I guess ill just buy them and find out
thegarr is offline
post #10 of 20 Old 12-12-2013, 10:53 PM
JonathanG's Avatar
Fyi-- Kinect has a lens that you can purchase and add that makes the useable area much bigger. Works pretty good on my front projector setup. Not sure about xbox one kinect but im sure there is one also.
Jonathan
JonathanG is offline
post #11 of 20 Old 12-13-2013, 09:19 AM - Thread Starter
bem1's Avatar
I believe what you are referring too is the Nyko Zoom product which is only for Kinect v1 (xbox 360).  The new Kinect v2, has a much wider field of view.
BTW, if you want Monoprice to create a cable extender for Kinect v2 (xbox one), check the following link:
http://monoprice.uservoice.com/forums/116957-new-product-suggestions/suggestions/5128547-xbox-one-kinect-2-0-extension-cable
bem1 is offline
post #12 of 20 Old 01-11-2014, 09:26 AM
globalist's Avatar
So how does the WHDMI work?
EPoX 9NPA+ Ultra - AMD Athlon64 s939 3200+ [email protected] -- Arctic Cooling Freezer64 Pro - Chill Innovation 450A2 - 1GB Corsair Value RAM DDR400 -- E-MU 0404 --> M-Audio Studiophile BX5a
globalist is offline
post #13 of 20 Old 01-11-2014, 11:43 AM
nphan's Avatar
Wireless HDMI works fine using a Denon receiver HDMI output for my w1500. However I only use HDMI cable since I already had the cable from my old projector.
nphan is offline
post #14 of 20 Old 01-11-2014, 11:54 AM
globalist's Avatar
What sort of distance are you talking? I mean could WHDMI be a problem if for instance you'd have your source in the next room, behind a wall/door?
post #15 of 20 Old 01-11-2014, 05:09 PM
nphan's Avatar
nphan is offline
post #16 of 20 Old 01-12-2014, 03:07 AM
globalist's Avatar
My W1500 is about 12 Ft from the Denon. You can go to
http://www.projectorreviews.com/benq/benq-w1500-projector-hardware-tour-2/#benq-w1500s-wireless-hdmi-whdi-dongle-transmitter
For more testing details.
Thanks, some review there. :P
All they have to say regarding the dongle range is
"While the wireless HDMI performance is fine – the signal is lossless (no degradation), and range is certainly acceptable within one room, and likely able to work if the source is in a nearby room."
Is that sentence even gramatically finished? One would expect a caveat after the whole "while" part...
Anyway if the signal is losless within one room as they say, then how is it only "acceptable"? And "likely able to work in a nearby room"? If they didn't bother to test this it makes me wonder if they tested the WHDI feature at all...
Could you maybe please test this for me, moving the projector to an adjacent room (closing the door)?
post #17 of 20 Old 01-12-2014, 09:25 AM
isamu's Avatar
Quoted: 46 Post(s)
Good points all around.
isamu is offline
post #18 of 20 Old 01-12-2014, 12:58 PM
nphan's Avatar
OK I tried the wireless HDMI using my WiiU in a bed room on the second floor and it works fine w/o any drops. I tried it for about 10 minutes.
The W1500 is on table top about 1.2 Ft off the floor in my 8 Ft ceiling family room on the 1st floor. With 2x10 floor joist with carpet in the bed room upstairs. This bed room is on top of the family room where the w1500 is located. So I would say the W1500 and the WiiU is about 13FT apart and separated by the ceiling wall. I would say this test is more stress than adjacent room case.
nphan is offline
post #19 of 20 Old 01-12-2014, 01:19 PM
globalist's Avatar
Although, I reckon the WiiU only outputs 720p max so who know what would happen with a 1080p source?
post #20 of 20 Old 01-12-2014, 04:59 PM
nphan's Avatar
The WiiU can output native 1080p/60Hz.
nphan is offline
Benq W1500 1080p Hd Wireless Dlp Home Theater Projector Silver , Benq W1070 3d Ready Dlp Projector 1080p Hdtv
