AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Digital Projectors - Under $3,000 USD MSRP (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/)
-   -   Sanyo PLV-Z4 still going, not sure what I would upgrade to? (https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/1505150-sanyo-plv-z4-still-going-not-sure-what-i-would-upgrade.html)
smithysmythe 12-12-2013 03:59 AM
I've been firing up the Z4 for 8 years now. Something I didn't plan on happening, but it still works really, really good. In its life it has only seen two bulbs; the original bulb and the replacement bulb that came with the unit as a promotion. I'm not even sure which bulb is in it now, since I've switched back and forth a few times or more. I do have to bump up gamma and open up iris to get enough brightness out of the dimming bulbs, but otherwise the projector works like it did 8 years ago. I've always been extremely satisfied with the color accuracy and content with the black level which looks damn good considering it is older technology. I use it for blu-ray and it is connected to my mac mini so I might watch OTA as well as web content. The video processing seems better than my flatscreen. Having said all of this, obviously I can't be completely satisfied with this aging unit and its 720p panels and its slight screen door effect.
Yet, I'm at all sure what to replace it with. It is on a rear shelf so I must have lens shift. It is in a totally dark room, although unfortunately the walls are white and there is not much i'm allowed to do about that. The only new projector I feel I would be happy with overall is the Epson 5030ub. I wish there were less expensive options. Anyone have some ideas you wouldn't mind sharing? And does anyone else still use a Z4?
Ken
Jim McC 12-12-2013 11:24 AM
Or the Panasonic 8000
newbomb_turk 03-29-2014 11:49 AM
I still have mine, and am still on the original bulb (2028 hours, 8 years later). It has been a fabulous projector, but does not get a lot of use.
I am going to drop in the replacement bulb and see if that brightens things up a bit.
I will be looking to upgrade in a year or so.
Bohanna 03-29-2014 03:07 PM
When you do put in the new lamp I would run it in economy mode for the first 500 or so hours until it starts to dim a bit otherwise you could cook the blue LCD panel and the Blue polariser and take a couple thousand hours or so off its life span. The quickest way to cook a well used LCD panel is to put in a fresh and powerful UV producing lamp.- Bohanna
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
