Acer H5360BD 3D Full with DUST - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-05-2014, 05:25 AM - Thread Starter
aresavs's Avatar
Hi,
For few years I have an Acer H5360BD 3D Video Projector.
I was very happy whit it until few weeks ago when dots of dust start to appear on my screen.
I tried with my vacuum cleaner without disassemble the projector, not success.
I tried to disassemble, but, to be honest, where i am now, i don't have enough tools, i have only a screwdriver and that's it. I cannot remove the first circuit board. I assume that it has 2 screws on the VGA plug
FOR ALL THE DESIGNERS AND THE ARCHITECTS IN THE WORLD, PLEASE, I BEG YOU, DON'T PUT THE MOST IMPORTANT PART OF A DEVICE LAST WHEN ASSEMBLING SOMETHING. :))
Does anyone have a schematics for disassemble this type of projector? or any idea how should i clean the dust ?
Thanks in advance,
aresavs is offline
post #2 of 5 Old 01-05-2014, 11:07 AM
RPS13's Avatar
Liked: 31
Is it dust or is it a bright white dot like a pixel has gone full white? Acers are unfortunately known for the DMD chip being undercooled and dying. The symptoms are stuck white pixels.
RPS13 is offline
post #3 of 5 Old 01-05-2014, 11:08 AM
RPS13's Avatar
Liked: 31
BTW - dust will show up as a slightly defocused/dark area on the screen since a small blob of dust is blocking a large and irregular portion of the projected image when it is small then blown up.
RPS13 is offline
post #4 of 5 Old 01-05-2014, 01:51 PM - Thread Starter
aresavs's Avatar
Hi,
After a closer look, apparently i don't believe is dust.
There a a lot of perfect square dots. white, black, some of them flick between red and black or white.
They are dead pixels.
As you can see in the picture attached, definitely is not dust.
Can i fix it? or should i buy another one? :)
What parts should i replace?
Thanks in advance,
aresavs is offline
post #5 of 5 Old 01-05-2014, 07:40 PM
RPS13's Avatar
Liked: 31
I'd contact Acer and see if they can help you. Probably not worth repairing a sub $500 projector out of pocket, even if you do the work yourself. The DMD is likely about $150+ retail.
I wouldn't get another Acer, this is very common with them which is immediately what I thought of when you mentioned dust. Unfortunately once the failure has started it usually accelerates and gets worse.
RPS13 is offline
Acer H5360 3d Dlp Projector
