Projector Room Setup with Pictures some help needed. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-07-2014, 01:43 PM - Thread Starter
chevytwonova's Avatar
Hello everyone here is a Photo of what i am trying to achieve down in my basement, all measurements are included in the photo. I already purchased the Elite screen 100" rigid frame for the setup. I am looking for a good projector for this setup something crisp that does 1080P. I am not really interested in the 3d if it comes with it that fine. I was checking out the Epson 5030UB that really looked great, but i don't want to drop 2500 on a projector. I am looking for something comparable to that projector but maybe from the 700 to 1500 range. Any suggestions would be great i appreciate the time to look this over! If you see any issues with the setup please let me know also....
chevytwonova is offline
post #2 of 19 Old 01-07-2014, 02:20 PM
rekbones's Avatar
Quoted: 915 Post(s)
Liked: 478
If your not willing to paint the room a darker color, including the floor and ceiling don't waste your money on a high contrast projector like the 5030ub. If your ceiling is high enough (over 8') and your darken the room the Mitts 7900 would be a great projector. The room as it is you should not consider a home theater projector but something more like the Benq 1070 or the optoma HD25LV for brighter light to overcome all the reflected light from the white surfaces.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 19 Old 01-07-2014, 02:31 PM - Thread Starter
room is going to be painted with a pastel mint color so it will be darkened up just waiting to paint because i need to run the power wire and HDMI from the front of the room to the ceiling mounted projector. I have about 92 inches from floor to ceiling.
post #4 of 19 Old 01-07-2014, 02:51 PM
airscapes's Avatar
Quoted: 489 Post(s)
Liked: 403
Not really the Dark Color Pallet that we use for HT.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #5 of 19 Old 01-07-2014, 03:11 PM
rekbones's Avatar
Quoted: 915 Post(s)
Liked: 478
Your ceiling is too low for the Mitts 7900 and any pastel color won't darken the room enough to help with contrast. I you want to use the room for other things then I understand the pastel color but a dark maroon, chocolate brown or midnight blue would work wonders for picture quality for any projector. I would still recommend a brighter Media room projector.
rekbones is offline
post #6 of 19 Old 01-07-2014, 03:25 PM - Thread Starter
yea leaning toward the HD25LV seem to be a lot of great reviews i am going to relocate the light in the center of the room to be closer to the stairway in the back of he room the pastel color is a compromise to the wife LOL..
post #7 of 19 Old 01-07-2014, 03:26 PM
airscapes's Avatar
Quoted: 489 Post(s)
Liked: 403
Chevy, take a read here, it is a short thread and and follow the links provided. Ceiling, wall and floor color (at least the first 5' from the screen) is really really important if you want success.
https://www.avsforum.com/t/1509248/how-much-do-white-walls-and-ceiling-hurt-my-setup/0_100
Doug
post #8 of 19 Old 01-07-2014, 03:43 PM - Thread Starter
yea i think i am going to paint darker to get the best performance just have to figure out how to blend with rest of the room HMMMM..
post #9 of 19 Old 01-07-2014, 04:11 PM - Thread Starter
So dark Color Pallet how dark are we talking about? would a Grey work like a gunmetal?
post #10 of 19 Old 01-08-2014, 02:13 PM
rekbones's Avatar
Quoted: 915 Post(s)
Liked: 478
Gun metal gray would be a good compromise (that's what I used for my ceiling). Just make sure you use flat paint not semi gloss or gloss.
rekbones is offline
post #11 of 19 Old 01-08-2014, 03:26 PM - Thread Starter
Did you use the same color for the ceiling and walls I would like to do the ceiling gun metal grey then do a shade lighter on the walls getting rid of the center light and adding 4 scones 2 on each side of the wall on a dimmer the beige carpet is staying with the optima hd25 Lv I think I will be fine with the extra brightness.. Anyone else think so?
post #12 of 19 Old 01-09-2014, 04:51 AM - Thread Starter
Since I will be painting the room darker and adding black curtains in between the first 2 pillars and getting rid of the center light should I go with the w1070 vs the brighter optima I wouldn't mind taking advantage of the 6x color wheel if the 1070 any opinions? Plus 200 cheaper is also appealing
post #13 of 19 Old 01-09-2014, 02:37 PM
rekbones's Avatar
Quoted: 915 Post(s)
Liked: 478
Now that your headed in the right direction for room treatment the HD25LV would not be needed. The 1070 or the HD131XE both have good plusses and minuses for about the same price.
rekbones is offline
post #14 of 19 Old 01-09-2014, 08:14 PM - Thread Starter
Ok so mounting this projector I currently have the screen 9" from the top of the screen to the ceiling with this gap be enough for my ceiling mount projector such as the hd131x or the 1070? I am not too aware of any mounts for projectors sorry for the questions but all help is much appreciated just want to do it right once.
post #15 of 19 Old 01-10-2014, 02:18 PM
rekbones's Avatar
Quoted: 915 Post(s)
Liked: 478
I believe the HD131xe has about a 8" offset so the lens would have to be 8" above the top of screen, hard to do for a 9" drop. The 1070 has a little bit of lens shift so it can be about 1" above the screen. Throw range is also different for each projector so check out the projector calculator for exact measurements.
rekbones is offline
post #16 of 19 Old 01-11-2014, 05:12 PM - Thread Starter
Have a chance to get the 8700ub for 700 with a brand new lamp vs the new benq1070 please let me know
post #17 of 19 Old 01-15-2014, 09:48 AM - Thread Starter
OK so i went to Homedepot and got some paint flat dark blue for the ceiling and flat dark grey for the walls. I am afraid after bringing this down to the basement it is too dark. I will post the picture of the swatch in a bit.
post #18 of 19 Old 01-15-2014, 08:11 PM - Thread Starter
Check out the progress what do you guys think?
post #19 of 19 Old 01-15-2014, 08:11 PM - Thread Starter
Optoma Hd25 Lv 3d Home Theater Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv
