Rear projector suggestion for small dark room (80-inch screen). Do I need to restrict light output from the projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-03-2014, 04:26 PM - Thread Starter
wsalopek's Avatar
Hi guys,
I have owned a few projectors over the years, but have now been on a 6-year drought. The house I am in now has a small room that I can use as a "theater"...viewing distance is about 9 feet, and from what I read from THX and SMTPE, I want about a 36-degree field-of-view, which amounts to an 80-inch screen (-ish).
I have been reading a lot of reviews, and sometimes folks talk about a projector being TOO BRIGHT for a room (wan't much of a concern 5-10 years ago, was it?). Even to the extent that the folks over at Projector Central talk of using a neutral density filter to cut down the projected light, even with a projector in ECO mode.
So...
My budget is less than $1000 (buying used is A-OK with me), 1080p for sure. And I'd love to get "good" black levels, but I also know I have to be realistic. Other than that, I am flexible. My screen is a white Draper with a 1.0 gain, but I could change that out if need be...maybe even by doing a DIY screen (my last screen was DIY with grey "Goo").
Thanks in advance for your suggestions.
wsalopek is offline
post #2 of 2 Old 02-03-2014, 04:57 PM
rekbones's Avatar
Quoted: 914 Post(s)
Liked: 477
The best bargain right now while they last is the Mits HC7900DW. I just received mine Fri replacing an Optoma HD33 and the black level is considerably improved. I had no complaints with the HD33 but this bargain was to much to pass up.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
Mitsubishi Hc7900dw Home Theater 3d Projector
