First Time PJ Owner – My selection after much research - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-05-2014, 12:30 PM - Thread Starter
thejoshster's Avatar
Background- I plan on being a new owner to a projector for my home theater/entertainment room. I don’t consider myself a hard core videophile, but I am technical and definitely pickier than the average person. I currently own a four year old Panasonic VT series plasma in the living room. Other than that I will have nothing to compare the new PJ setup to. I love how vibrate and accurate the color is on the plasma. I am hoping to get the best possible picture that makes sense dollar wise.
Use case- The projector will be used as movies/3d gaming/DirecTV. I would like to be able to have a small amount of ambient light when watching sports games with friends. I will have complete control over lighting in a basement via canned lights. Ceiling will be black with dark grey walls. Otherwise, the room will be completely dark for other activities. I realize I am asking for the PJ to do it all:) I would break it down to this:
Blu-ray/HD movies 35%
DirecTV sports 35%
Gaming 15%
3D Gaming/ 3D Blu-ray 15%
3D and gaming are at the lower end of my priorities, but I still want a high level of performance for those. I will likely enjoy the occasion animated 3D movie with the family. The 3D gaming will mostly be for Sim racing from PC, which 3D greatly enhances the immersion.
Equipment-With needs above in mind, here is what I have selected so far:
PJ- Epson 5030ub – I feel this the best all-around projector at reasonable price. It should be able to cut through some ambient light when required to. Seems decent at 3D and decent input lag(37ms) when in fast processing mode
Screen – 120” 16:9 Elite Fixed mount with Cinewhite- 1.1 gain
AVR/Audio- not being discussed in this thread
Here is the layout:
pic1.jpg 67k .jpg file
pic2.jpg 43k .jpg file
I like the idea of a U shaped couch for hanging out. I would not consider the extreme edges of the couch to be watchable seats. The seats I consider to be watchable are 10-12’ from the center of the screen. This will seat up 8 people. While some of the outer seats are not ideal, they are still mostly within the width of the screen. I would consider moving the couch back a bit, but the posts in the basement are preventing it. The post on the far left will be removed. The projector will be ceiling mount within a few inches of the minimum for a 120" screen. I am thinking keeping the PJ as close as possible to keep brightness up.
Anyway, I didn't want this to be a HT build thread. I just want some thoughts on the Projector choice, screen, and seating. I feel like it’s a little on the aggressive side for the size of the room, but it should offer a great balance between entertaining guests and dedicated movies/games.
Any thoughts are appreciated.
ID:	75561   Click image for larger version
thejoshster is offline
post #2 of 2 Old 02-05-2014, 03:30 PM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 480
Sounds like a good plan the 5030 should work well in that room although it does have some gaming lag and 3D is not as good as the DLP models. I would look at the Mits HC7900DW at $799 its 1/3 the cost of the 5030, great 3D ( I don't know about LAG but DLP's are usually good) although not as bright. If you design your lights so they don't shine on the screen ether directly or reflectively it should be OK.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
Mitsubishi Hc7900dw Home Theater 3d Projector , Epson 5030ub 2d 3d 1080p 3lcd Projector
