BenQ W1080ST Firmware Questions THANKS! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #31 of 46 Old 11-20-2014, 04:52 AM
lilcheeks's Avatar
Originally Posted by Yabizar View Post
Its uploading now, i used mediafire i made an account and everything so this should stay up way longer. Sorry for the links breaking guys. I am trying everything i possibly can! New link will be posted back at the top of this thread. its 60% done
Thank you, thank you, thank you!
lilcheeks is offline
post #32 of 46 Old 11-21-2014, 01:28 PM
baux's Avatar
thanks!finally!
baux is offline
post #33 of 46 Old 12-16-2014, 08:43 PM
xbrady's Avatar
Originally Posted by darrin0 View Post
FINALLY!!!!! After hours and hours of searching I found on a website in some other language a working username and password to download the benq w1070 or benq w1080st firmware. (same ftp site as posted above, but new and working username/password)
ftp://62.141.76.120/driver/projectors/W1070/
ftp://62.141.76.120/driver/projectors/W1080ST/
login: User
password: pass2005
The password is now: pass2002
xbrady is offline
post #34 of 46 Old 12-17-2014, 04:37 AM - Thread Starter
Yabizar's Avatar
The 3rd post has a download link that includes all the files needed. no password required
Yabizar is offline
post #35 of 46 Old 01-16-2015, 07:39 PM
a4pat's Avatar
thank you for this! worked like a charm for me.
Patrick
a4pat is offline
post #36 of 46 Old 01-16-2015, 10:08 PM - Thread Starter
Yabizar's Avatar
NP Glad it went good for u!
Yabizar is offline
post #37 of 46 Old 02-06-2015, 04:23 AM
Liked: 0
Don't work the user and pass, please update . Thanks
victorthemad is offline
post #38 of 46 Old 02-22-2015, 10:51 PM - Thread Starter
Yabizar's Avatar
..............3rd post on the first page
Yabizar is offline
post #39 of 46 Old 03-04-2015, 02:17 AM
Liked: 0
hello,
I have one question.
What's the latest firmware for W1080ST?
arkoch is offline
post #40 of 46 Old 08-25-2015, 11:28 PM
tanwn1's Avatar
Quoted: 121 Post(s)
Liked: 41
can i update my w1080st+ with a plus model using these firmware? Are they applicable to the plus + model as well?
tanwn1 is offline
post #41 of 46 Old 10-01-2015, 04:27 PM
tanwn1's Avatar
Quoted: 121 Post(s)
Liked: 41
NEVER NEVER use 1080st firmware on a 1080st+, i bricked it and had to sent it back to the factory to replace the board. I did not tell them i do the update, so the replacement was free as it was under warranty.
tanwn1 is offline
post #42 of 46 Old 10-10-2015, 04:24 AM
Liked: 0
What is the last version of firmware Benq 1080st+ ?
Thanks you for answer
NEWBENQ is offline
post #43 of 46 Old 10-10-2015, 07:31 AM
tanwn1's Avatar
Quoted: 121 Post(s)
Liked: 41
I have no idea but mine came with 1.02. It has the menu background color as well as 3d sbs top bottom.
tanwn1 is offline
post #44 of 46 Old 12-26-2015, 07:32 PM
butie120's Avatar
Quoted: 1122 Post(s)
Liked: 364
I have the original W1080st and am having some issues with playing back Netflix 3D. It takes a very long time to load, and while it may play for a few minutes, it then will buffer again for a long time. I have 40mpbs download speed so that's not an issue. I have the Sony BDP S6200. I have the latest firmware to my knowledge, 1.05, but I can't select side by side as an option for 3D. I have never tried 3D using a blu ray 3D disk yet so not sure if options open up, but for at least 3D streaming I can only do top bottom, and then it switches to frame packing.
Any things I could try at this point? Thanks!
butie120 is offline
post #45 of 46 Old 03-05-2017, 07:46 AM
Liked: 0
Hello friends,
I just got a BenQ HT1085ST that I'm trying to fix. The person I got it from Bricked it by updating the firmware with the firmware for the w1080st. And now I need a copy of the eeprom to reflash, Before I buy anther one of these projectors just to copy the eeprom myself, I thought I would ask if anyone could help me finding the right file or a donor board. Thank You
Best of days
Andrew
simwewo is offline
post #46 of 46 Old 03-10-2017, 12:28 PM
Liked: 0
Originally Posted by simwewo View Post
Hello friends,
Best of days
Andrew
I'm in a similar boat and would love any files/help towards fixing a bricked HT1080ST. Thanks!
nacire is offline
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
