SONY VPL-HW40ES : New SONY SXRD 1080P home theater projector - Page 171 - AVS Forum | Home Theater Discussions And Reviews
 595Likes
post #5101 of 5106 Old 03-21-2019, 08:47 AM
Legairre's Avatar
Quoted: 1205 Post(s)
Liked: 663
Originally Posted by tab10 View Post
Bump. We just moved into a new home with a media room. We asked for the HT setup as a seller's concession and they agreed. So we got a HW40ES projector and a 120 inch screen (can't tell the brand). I cannot get this projector to align image properly for the life of me. It slopes off to the right at the bottom.
I'm at my wit's end. I don't know if it is the screen, PJ, or some combo of both.
Take a level and make sure the screen is level. Check both the top and bottom. Also make sure the screen isn't warped and all four corners are the same distance from the wall behind the screen. That way we'll know if the screen is the problem. If it's not the screen then we need to make sure projector is level and pointed completely straight at the screen.
Can you post some pics of the image? BTW the 40ES has two wheels on the top to move the image up/down and L/R for horizontal and vertical lens shift if you need them.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #5102 of 5106 Old 03-22-2019, 05:06 AM
Quoted: 83 Post(s)
Liked: 1
is there a big difference in the sony 40es and the 45es i see that i can get a good use 40es for a good price please explain thank...
quentinnw2 is offline
post #5103 of 5106 Old 03-22-2019, 09:54 AM
horseflesh's Avatar
Quoted: 105 Post(s)
Liked: 50
The short answer is there is not a big difference. I still love my 40, so if you can get a good price go for it.
Long answer here:
https://www.avsforum.com/forum/68-di...successor.html
horseflesh is offline
post #5104 of 5106 Old 09-10-2019, 03:14 PM
reisb's Avatar
Quoted: 57 Post(s)
I'm finally due to replace lamp. What are the thoughts on places to purchase as of now? projectorlampexperts.com, projectorpeople, or somewhere else?
reisb is offline
post #5105 of 5106 Old 09-10-2019, 07:48 PM
73shark's Avatar
Quoted: 560 Post(s)
Liked: 280
I've had good success w/ Projector Lamp Experts. YMMV
Their Platinum lamp has a one year warranty.
In space, no one can hear you scream . . .
73shark is offline
post #5106 of 5106 Old 09-11-2019, 07:19 AM
Legairre's Avatar
Liked: 663
I've bought OEM and the platinum lamps from projectorlampexperts.com. I never had a problem with either and only buy the platinum lamps from them now because they have lasted and performed the same as the OEM but at a lower price.
Legairre is offline
