Optoma HD161X - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #91 of 117 Old 04-27-2015, 05:01 PM
3DBob's Avatar
Quoted: 1153 Post(s)
Liked: 638
Thanks for the input, guys. I receive it tomorrow and can do a side-by-side test with the 131x. I am a little worried about fan noise, but not as susceptible to it as most people. Well, it if doesn't work, it goes back to Amazon, but I will give a try. I really miss the sharpness of a glass lens, some of the lens shift the 161x can do and the pure motion, which the HD33 did nicely.
3DBob is online now
post #92 of 117 Old 04-28-2015, 12:08 PM
3DBob's Avatar
Liked: 638
Well, I received my HD161X today and compared it to my HD131X. I was surprised that I could get the brightness close to the 131X, but it wasn't the brightness that bothered me. It was the soft image. With a glass lens, the image is surprisingly soft. The 131X image was definitely sharper, and had more pop in 3D with objects more defined. It was a real head scratcher, as I had predicted the HD161X to run circles around the 131X. I could not see much difference in black levels either. Their might have been more detail in the shadows on the HD161X, but that was at the cost of contrast. Turn the contrast up and the detail is about the same, but the 131X is more pleasing to watch--at least to me. Oh well, it was from Amazon, so it's going back. I also realized that the 131X, while it doesn't have pure motion, 24p movies look as good as the 161X with pure motion set to low, so I'm thinking the firmware has this builtin. And no, I didn't calibrate the HD161X. I didn't have to, the softer image (I note some on this forum it looked dull) would have made my decision regardless.
If you're thinking about upgrading from the 131X, don't bother, it's pretty dang good for the money considering, and 3D is very watchable. And for what the HD161X costs, you could almost buy two of them. I'm assuming the HD141X would be as good as the 131X as well.
3DBob is online now
post #93 of 117 Old 04-29-2015, 11:06 AM
3DBob's Avatar
Liked: 638
I forgot to add, that although I did not calibrate the HD161X, the color seemed okay out of the box. That said, there definitely is a different look to colors from the RGBRGB wheel of the 161X and the RGBCMY (I think) wheel of the 131X. It seemed that the color pallet of the 131X was wider and not so 3-color looking. The Reds, Greens and Blues of the 161X were very Red, Green and Blue vs. also having pure Cyan, Magenta and Yellow colors. Seemed odd to me, but maybe that's just the lack of calibration on the 161X. I did not see rainbows on the 161X as it has a 4X wheel. The 131X has a 2X wheel, but I'm not susceptible to rainbows, so it doesn't bother me, but if you are, then the 161X might be better.
3DBob is online now
post #94 of 117 Old 04-30-2015, 12:48 AM
Liked: 0
Here is some good calibration I have found on the web
Display Mode: Reference
Contrast: 0
Brightness: 0
Colour: 0
Tint: 0
Sharpness: 8
Advanced
Noise Reduction: 0
Gamma: Film
BrilliantColor: 1
DynamicBlack: Off
Colour Settings
Colour Temperature: D65
Colour Gamut: HDTV
Colour Space: Auto
RGB Channel: Normal
RGB Gain/Bias: Red Gain 0, Green Gain -3, Blue Gain +2, Red Bias 0, Green Bias 0, Blue Bias 0
CMS: Red (X Offset 0, Y Offset 0, Brightness -20), Green (0, -16, +26), Blue (0, -25, -20), Cyan (+10, +10, +14), Magenta (-12, -13, -10), Yellow (-11, +1, +7)
Pure Engine
UltraDetail: Off
PureColour: Off
PureMotion: Off
Display
Format: Native
salemaxa is offline
post #95 of 117 Old 05-01-2015, 01:46 PM
3DBob's Avatar
Liked: 638
Thanks for the calibration update. I didn't want to sound too negative about the 161x. I'm just saying that if you have a 131X, you won't get enough features to offset the 3D brightness and pop of the 131X image, unless you only watch 2D.
3DBob is online now
post #96 of 117 Old 09-10-2015, 11:04 AM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
well I feel like I Did really well, but now I am nervous about lag. I got a hd161 on ebay for 800 (it said it was a store return, but I called and they said it was actually a refused projector, and it hasnt been opened) it includes the wireless HDMI and has 10 months left on its warranty...I felt like I did really well, but now yall have me worried lol. I upgraded from a epson 8345 which was awesome, but I missed 3d...any thoughts on brightness and comparison between these two?
stuart628 is offline
post #97 of 117 Old 09-10-2015, 11:23 AM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
That's a good deal assuming it's as new as claimed.
I've seen this projector in action (well, the brick-and-mortar version: the HD50) and while normal pricing is a bit on the high side, the kind of deal you've got here is excellent. (It throws out a very, very solid image: certainly worth more than $800 IMHO). Unless you're a relatively serious gamer, lag shouldn't be an issue for regular video watching.
Send your experiences our way when it arrives.
BenQ HT2050A Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
kreeturez is offline
post #98 of 117 Old 09-10-2015, 11:47 AM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
That makes me feel better...I am a gamer but I am hoping lag won't bother me....any thoughts on 8345 vs 161x?
post #99 of 117 Old 09-10-2015, 12:09 PM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Optoma HD161X
Uh oh. I suspect you'll notice: it's in the region of 150ms; that's high for anything beyond casual gaming.
The 8345 has much less lag and much more placement flexibility (but no 3D; slightly dimmer; more SDE; a bit more motion blur).
Most gamers here (myself included) are going to recommend the W1070; which retails for less than you've already paid and games extraordinarily well. I saw both the W1070 and HD50 post-calibration and actually slightly preferred the resulting image from the HD50 (which is why $800 classifies as a good deal by me); but if you need to game on it, very-high input lag on the Optoma is deal-breaking.
It's not the kind of thing that gamers don't notice: you press a button, and the response is delayed.
post #100 of 117 Old 09-10-2015, 01:05 PM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
lol oh man, I am just getting ready to get battlefront too, lol, oh well...I am really looking forward to this projector seems like a great deal, we will see....also its from Beach audio and they said it was a rejected (not opened) projector, seemed pretty confident and dont think they would have a reason to lie.
post #101 of 117 Old 09-12-2015, 03:26 PM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
Well got it in so far so great good lumens nice color haven't played a fps yet but the baseball game i played wasn't terrible can't wait to see some 3d!!
post #102 of 117 Old 09-12-2015, 09:20 PM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Good to hear it! Very solid deal you got there! Check the lamp counter: it should be near zero assuming it was unopened (and not reset...)
Send some more feedback once you've spent some more time playing with this new AV gear!
post #103 of 117 Old 09-13-2015, 12:01 AM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
Box was still factory sealed. Counter at zero
kreeturez likes this.
post #104 of 117 Old 09-14-2015, 07:37 AM
stuart628's Avatar
Quoted: 99 Post(s)
Liked: 36
Quick shot from the iPhone last night while we watched the Dallas game...very happy with this projector. This is on vivid, out of box only 4 hours on projector so no calibration yet
post #105 of 117 Old 11-20-2015, 10:39 AM
detroit1's Avatar
Quoted: 203 Post(s)
Liked: 42
how would everyone compare the 161X vs the Sony 55ES ?
detroit1 is offline
post #106 of 117 Old 01-21-2016, 01:15 PM
kevinf's Avatar
no video
I just replaced my Sanyo plvz5 (720p) with the Optoma HD161 (1080p) and my tv is a 720p all switched through my receiver but I no have no video displayed on my projector unless I plug a source like Western Digital play . There could be two things happening here the mix of a 720p tv and the 1080p projector are causing HDMI issues and the existing 25 foot HDMI cable in my ceiling can not pass 1080p signal .P.S. I pluged my Nexus player directly into the 25 HDMI cable and still no video any ideas ?
kevinf is offline
post #107 of 117 Old 01-21-2016, 07:20 PM
Rafael Taveras's Avatar
Keivnf I think this is your problem. I would disconnect your TV and reset your settings in the receiver. I've owned this projector since May of last year and love it
Rafael Taveras is offline
post #108 of 117 Old 01-22-2016, 04:19 PM
kevinf's Avatar
What settings would you suggest?
kevinf is offline
post #109 of 117 Old 01-23-2016, 08:10 AM
The reason I said this could be the problem is I had a HDMI splitter in my setup and it mentioned that if the signal was going out to two devices that did not have the same resolution . The splitter would chose the resolution that was compatible with both devices or it simply would not out put a signal.
post #110 of 117 Old 01-23-2016, 08:15 AM
Kevin I have my projector connected directly to my blu -ray player. ( Oppo BPD -103D) Using Spears & Munsil disc for a basic setup up not full calibration . My settings are
Contrast: 0
Brightness: - 3
Color: 0
Tint: - 1
Sharpness: 8
Advanced
Noise Reduction: 0
Gamma: Film
Brilliant Color: 1
Dynamic Black: Off
Color Settings
Color Temperature: D65
Color Gamut: HDTV
Color Space: Auto
RGB Channel: Normal
Pure Engine
Ultra Detail: Off
PureColour: Off
Pure Motion: Off
Display
Format: 16.9
A few other settings
I use 16.9 for format because if the projector receives a 720 P signal from my cable box the image is pillar boxed . If you don’t have this problem use Native.
Source lock : On
I also unchecked the inputs that I’m not using that way the projector locks on to the signal much faster. I only have HDMI 1and 2 checked.
If your image looks noisy after setup give the lamp sometime to break in and settle. I found that at around 30 hour mark the contrast improved dramatically and the noise virtually disappeared.
post #111 of 117 Old 01-24-2016, 09:57 AM
kevinf's Avatar
Still nothing
no video
So I tried plugging two different devices into the HDMI wall plug thats attached to my projector 25' of cable away and nothing . Is there a chance my HDMI cable and my new projector cant get along ?
kevinf is offline
post #112 of 117 Old 01-24-2016, 05:01 PM
Kevin sorry to hear it‘s still not working . There is always a chance that it’s your cable. It seems you have tried everything else.
This is the cable that I have in my setup. http://www.solidsignal.com/pview.asp?p=WV1012 It’s a 25 foot redmere cable. One of the real advantages to these HDMI cables besides redmere tech is compared to the cables I purchased 8 years ago is that they are super thin and flexible.
Please keep me up to date with your situation.
post #113 of 117 Old 09-07-2018, 02:47 PM
Glidedon's Avatar
Ok my Hd161x blew out the bulb last night. Loud pop and puff of smoke.
The projector has been used as main display device for TV, Movies for almost 4 years.
The question is should I buy a replacement bulb on this moderately heavily used unit?
I like the Projector, it fits my needs, however a new bulb does not guarantee a fixed projector or extended life, right?
Im intrigued buy the Laser projectors but only lower priced units would be within my budget.
So do I take a chance on a new bulb or apply the money to a new projector?
Oh and bulb seller recommendations?
TIA
Don
Glidedon is offline
post #114 of 117 Old 01-02-2019, 03:18 AM
Liked: 0
You can buy a original lamp, the cost is around 60€ and the change is easy. Take a look of number and type of lamp and buy it
Enviado desde mi Redmi 3 mediante Tapatalk
raulata is online now
post #115 of 117 Old 05-04-2019, 09:13 PM
jocanton's Avatar
Quoted: 51 Post(s)
My Optoma HD161X now just shows the logo at start up and acts like it's working fine, LED is solid green, ect...but no picture displays after the logo screen is done. Has anyone else had this happen or have any clue what is going on and if it can be fixed?
jocanton is offline
post #116 of 117 Old 06-30-2020, 12:40 AM
padthebear's Avatar
Liked: 0
Hi
I know it's while since you posted this fault with your 161x,
I have the very same issue,
Just wondering what was the outcome with yours?
padthebear is offline
post #117 of 117 Old 06-30-2020, 05:46 PM
GregK's Avatar
Quoted: 18 Post(s)
Liked: 32
Dust Blobs
My HD161X has acquired some dust blobs. Anyone have a good tutorial for dealing with that with this particular projector?
GregK is offline
