Benq W600 light issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-03-2014, 11:30 AM - Thread Starter
Liked: 0
In my projector, i've got a line with a darker image. It's small, but really frustrating.
Any thoughts on why this happens? easy fix?
I appreciate any help
ID:	244097   Click image for larger version
ID:	244105   Click image for larger version
ID:	244113   Click image for larger version
ID:	244121   Click image for larger version
Adrián Figueroa is offline
post #2 of 4 Old 09-03-2014, 01:10 PM
Ftoast's Avatar
Quoted: 2683 Post(s)
Liked: 874
I've heard this is what happens with a collapsing light tunnel. They're repairable to some extent if that is the cause, so I'd suggest doing a quick search on repairing a collapsed light tunnel and hopefully someone with more insight will speak-up whilst you're reading.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 4 Old 09-04-2014, 01:23 PM - Thread Starter
Liked: 0
Thank you so much! You were right, and after a hard research, i fix it!
Thanks again
post #4 of 4 Old 09-04-2014, 04:08 PM
Ftoast's Avatar
Liked: 874
Thanks again
That's great!
Would you mind linking what directions you ended up using and maybe describing the process a little for anyone else who might end up in the same boat?
Also, try to remember what you did well, because I've heard it tends to become a reoccurring problem at least for some. So you might end up needing to fix it again at some point.
Ftoast is offline
