Official Sony VPL-HW40ES Owners/Settings Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
post #61 of 1629 Old 12-14-2014, 05:56 PM
Tom899's Avatar
Quoted: 176 Post(s)
Liked: 83
Originally Posted by horseflesh View Post
I have a 135" 1.0 screen and my PJ is mounted at about 14 ft back.
At this distance, I find the brightness in 3D mode to be totally adequate. Adequate, not eye-poppin' awesome. I'd make it brighter if I could. It simply isn't "IMAX bright" in this configuration.
Based on this experience, I'd be concerned that 21-22 ft might be too far away for pleasing 3D brightness.
I'm getting ready to mount my 40ES soon. Projector Centrals calculator says 16' 4" for my 134" screen. I see you are at 14'. I'm trying to understand what distance I should go with? What would be the best? I only want to mount this once.
Pioneer UDP-LX500 | Denon AVR-X4400H | Emotiva A-300 2ch amp | Emotiva PA-1 monoblock | JVC DLA-RS1000 Projector | Mini DSP 4x2 | Dune HD Smart D1 | ZIDOO Z9S | Buttkicker system | HSU VTF-3 MK4 subs(2) | HSU MBM-12 MK2 Mid bass module | Klipsch RP-8000F(2) | Klipsch RP-504C | Klipsch RS-62 II(2) | Polk RC80i Ceiling(4) | Carada 134” screen | unRAID 40TB
Tom899 is offline
post #62 of 1629 Old 12-14-2014, 06:08 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
You won't have to worry about brightness so your good to mount it 16' back. Mount it where it's optimum for your room.
Crabalocker is offline
post #63 of 1629 Old 12-14-2014, 06:16 PM
Tom899's Avatar
Quoted: 176 Post(s)
Liked: 83
Thanks Crabalocker, My room is very deep, I can mount it from very close to 35' back (obviously won't do that). So I don't know what optimal is? If 16' is the perfect sweet spot than I will use that.
Tom899 is offline
post #64 of 1629 Old 12-14-2014, 07:10 PM
horseflesh's Avatar
Quoted: 111 Post(s)
Liked: 52
My PJ is at that distance only because it's where it had to be for the room.
horseflesh is offline
post #65 of 1629 Old 12-14-2014, 07:42 PM
lespaulman's Avatar
Quoted: 117 Post(s)
I have 135" fixed 1.1 Elite screen and my Sony 40es is mounted at 13' 6" to front of lens. Mine is very bright and looks amazing.
lespaulman is offline
post #66 of 1629 Old 12-14-2014, 10:02 PM
Kilgore's Avatar
Quoted: 729 Post(s)
Liked: 443
Originally Posted by quakana View Post
Have any of you guys has Keystone issues with the Sony VPL-HW40ES? I am looking at buying one and will be ceiling mounting and read a bad review relating to this on amazon. I currently have a Panasonic PT-AR100 which has keystone control through the remote (electronic?) and have a trapezoid shaped pic would drive me nuts!
You should never have to use keystone with a projector that uses lens shift like the Sony. To avoid a trapezoidal image, you must start out with the PJ level with the floor, and projecting perpendicularly to and directly straight at the opposing wall that contains the screen, regardless of where on the wall the screen is, and then using the lens shift controls to move the image onto the screen.
To recap.
1: Make sure PJ is level with the floor
2: Point the PJ directly at the wall so the beam is perpendicular to the plane of the wall.
3: Use lens shift to move the image to the screen.
It's simple, really. I refuse to buy a PJ that doesn't have lens shift. It makes things SOOOOOO mush easier and gives you so many options for PJ location. Phooey on offsets!
Kilgore is offline
post #67 of 1629 Old 12-15-2014, 02:01 AM
mike123abc's Avatar
Quoted: 113 Post(s)
Liked: 116
The only reason you would have a keystone problem is if you mount the projector too high/low (or side to side) of the screen that it is out of range of the lens shift, and you had to tilt the projector.
mike123abc is offline
post #68 of 1629 Old 12-16-2014, 12:05 PM
Craig Peer's Avatar
Quoted: 8057 Post(s)
Liked: 10652
" You should never have to use keystone with a projector that uses lens shift like the Sony. To avoid a trapezoidal image, you must start out with the PJ level with the floor, and projecting perpendicularly to and directly straight at the opposing wall that contains the screen, regardless of where on the wall the screen is, and then using the lens shift controls to move the image onto the screen. "
Keystone correction should be eliminated from home theater projectors for the users own good !
ben38 and Kilgore like this.
Craig Peer is offline
post #69 of 1629 Old 12-16-2014, 05:19 PM
Quoted: 17 Post(s)
Liked: 0
Has anybody used the Sony VPL-HW40ES on a 150" screen? How does the Sony VPL-HW40ES look on a 150" screen? I'm debating between a 135" screen or a 150" screen, I was wondering if this projector loses any image quality as it gets bigger.
johann777 is offline
post #70 of 1629 Old 12-17-2014, 10:28 AM
Mike Garrett's Avatar
Quoted: 14048 Post(s)
Liked: 11723
All projected images lose quality as you make them bigger. I doubt that you are really going to notice much if any difference in image quality going from 135" to 150" The 40 has enough lumens for a 150" screen, especially so if you get a screen with a little gain.
Mike Garrett is offline
post #71 of 1629 Old 12-19-2014, 08:01 AM
Soxfan111111's Avatar
Quoted: 42 Post(s)
Cable tv image quality
So I have this projector ceiling mounted on a 120" screen. Blu-ray's look fantastic, but I also use it for cable television watching, which I get with Comcast running through a TiVo mini box. I am not nearly as satisfied with TiVo image quality, and not just because it obviously isn't going to look as good as blu-ray, but that it doesn't even come close to what my 60" plasma achieves. For the most part close-ups look good, but wide shots really suffer, with lots of grain and artifacts showing up.
Is this just a function of the image being blown up so much bigger and therefore the weakness of the picture becomes more apparent?
Are there possibly any settings out there someone could point me to that might improve a cable television image?
Soxfan111111 is offline
post #72 of 1629 Old 12-19-2014, 08:17 AM
hv9200's Avatar
Quoted: 119 Post(s)
Liked: 74
I have noticed same issue with my set up (also 120" and also using TiVo), its basically the signal coming in, I see a tremendous differences in the picture quality from channel to channel, in my setup HBO, Showtime look great but AMC and FX look somewhat grainy I don't have artifacts though...the picture is not poor but not great either. I have played with the settings but IMO you are just not going to be able to get as good an image on 120" projection that you will with you plasma with a cable TV signal.
"although he walks among us, he is not one of us"
hv9200 is offline
post #73 of 1629 Old 12-19-2014, 08:20 AM
hendry98's Avatar
Quoted: 97 Post(s)
Liked: 8
I just bought Sony HW40 for my new HT, but still in the box, any recommendation for specific Ceiling Mounting Kit (black material) for this projector?
this is my first projector, and i have zero experience with projectors/mounting kits
p.s., most likely will order the kit from amazon.
hendry98 is offline
post #74 of 1629 Old 12-19-2014, 08:24 AM
tcramer's Avatar
Quoted: 475 Post(s)
Liked: 251
Yep, the same here. The biggest letdown to me is football. The typical field view is never that great but it still looks good on my VT50 but it almost always looks crappy on my 110' screen. Like you said, some channels aren't bad and the closeups are usually good, but most things it will take some adjusting to get used to the decreased PQ on the big screen.
tcramer is offline
post #75 of 1629 Old 12-19-2014, 08:40 AM
hv9200's Avatar
Quoted: 119 Post(s)
Liked: 74
I use the peerless universal (black) and the 6-9" adjustable extension tube...worked good for me and yes...I bought it from Amazon
hendry98 likes this.
hv9200 is offline
post #76 of 1629 Old 12-19-2014, 08:45 AM
Quoted: 182 Post(s)
Liked: 122
I run 153" 16x9 and the HW40 is plenty bright.
As you go bigger, source material becomes paramount. Any flaws become exaggerated as you enlarge the image. I sit 14-15' from my screen and it looks really good. HD TV looks good on some channels, not so good on others.....Bell ExpressVu compresses their signal so you're not watching true HD. Blu-ray looks really good! As stated above...NFL football on the network channels doesn't look all that great, on TSN (CFL) looks pretty good. If you can pick up the HD channels locally with an antenna....I hear that makes all the difference, but I don't have first hand knowledge of that.
If it were me and I was sitting 12'ish feet from my screen, I'd go 135". If I were sitting 14 feet or further back, I'd go 150"
To give you size comparison... here's a shot of my 153" A/T screen and if you look closely you can make out my old painted screen (now painted black) which was 133". Just to give you some perspective with the size differences.
post #77 of 1629 Old 12-19-2014, 01:28 PM
hendry98's Avatar
Quoted: 97 Post(s)
Liked: 8
I have order AT 150" screen (16:9) and Sony HW40, but my first row will be 14-15' from the screen.
So i am in the same boat
hendry98 is offline
post #78 of 1629 Old 12-19-2014, 01:29 PM
hendry98's Avatar
Quoted: 97 Post(s)
Liked: 8
Awesome, thanks a lot, i will check it out now.
are referring to this one:
http://www.amazon.com/Peerless-PRGUN...=pd_cp_e_1#Ask
hendry98 is offline
post #79 of 1629 Old 12-19-2014, 01:31 PM
hendry98's Avatar
Quoted: 97 Post(s)
Liked: 8
if you go back to 19-20', would the HD TV image get better?
hendry98 is offline
post #80 of 1629 Old 12-19-2014, 07:35 PM
Quoted: 182 Post(s)
Liked: 122
Most television channels look good...for the most part. Moving back doesn't really help....maybe a bit but it's not like on a smaller TV. It's hard to explain. But for most of your TV viewing it will look really good.
The only other weird television issue I experience is that some channels, the show itself is on the dim side.... I have to put the lamp on high. The commercials will be at normal brightness levels but the show itself goes dim. Sports appear bright.
I'm not sure why NFL looks...well not great on ExpressVu. When I watch the highlights on TSN it looks fine. It seems like it's more of a dish issue rather than a projector issue. I'm glad I'm not a football fan anymore.
post #81 of 1629 Old 12-19-2014, 07:52 PM
lespaulman's Avatar
Quoted: 117 Post(s)
Attachment 431018
what screen material do you have? And where did you get it from.
post #82 of 1629 Old 12-20-2014, 12:45 AM
Quoted: 182 Post(s)
Liked: 122
It's a Seymour xd screen and I got the material from....Seymour AV. I bought the material and built my own frame and false wall. Acoustically transparent screens are awesome!! I have zero regrets going this route.
post #83 of 1629 Old 12-20-2014, 07:33 AM
Quoted: 17 Post(s)
Liked: 0
Attachment 431018
Thanks, I'll be sitting about 15-17 feet away.
I was trying to figure out whether to do a plus gain or not since I have to do a AT screen. I debating between the Falcon Horizon screen at 1.0 gain or the Seymour Centerstage XD (1.2 gain screen)
Which screen is yours?
post #84 of 1629 Old 12-20-2014, 09:08 AM
Quoted: 182 Post(s)
Liked: 122
Look one post above yours.... I have a Seymour xd screen. (Center Stage xd)
I found this, measuring screens. Go to page 18, they have a section on acoustically transparent screens. http://www.accucalhd.com/documents/a...een_report.pdf
post #85 of 1629 Old 12-20-2014, 12:09 PM
badgerpilot's Avatar
Quoted: 76 Post(s)
Liked: 46
For TV signals, I figured out a long time ago that using an OTA antenna is the way to go for the main channels. I have DISH and some channels are ok but for football games on FOX, NBC, CBS and ABC I use the OTA signal. No compression and the picture is excellent.
Crabalocker likes this.
badgerpilot is offline
post #86 of 1629 Old 12-22-2014, 08:50 AM
Schlemstar's Avatar
Quoted: 28 Post(s)
Liked: 24
That's interesting because just yesterday I was trying to figure out why the football games looked so bad. It seemed like close-up shots were very crisp, but wide-angle views of the whole field were very noisy looking. I thought maybe they were using different cameras or something, but the picture was the same on CBS and FOX.
I also read that some people turn Reality Creation off for cable TV viewing. I was going to try that tonight, but maybe going OTA is the way to go...
Do you have a separate antenna for that? If so, which one?
Schlemstar is offline
post #87 of 1629 Old 12-22-2014, 09:09 AM
Quoted: 76 Post(s)
Liked: 46
I have a powered Terk antenna that I have had for at least 10 years. I have it mounted in my attic. I don't think they make the model I have anymore but I am sure their current antennas are just as good if not better.
post #88 of 1629 Old 12-23-2014, 06:17 AM
Schlemstar's Avatar
Quoted: 28 Post(s)
Liked: 24
What do you use as a tuner?
post #89 of 1629 Old 12-23-2014, 06:49 AM
hv9200's Avatar
Quoted: 119 Post(s)
Liked: 74
yep, that's the one I used
hv9200 is offline
post #90 of 1629 Old 12-23-2014, 08:43 AM
Quoted: 76 Post(s)
Liked: 46
I have a dish hopper with the OTA tuner add on. Works great!
computer , hw40es , Sony , VPL-HW40ES
