Official Sony VPL-HW40ES Owners/Settings Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
post #1621 of 1629 Old 06-29-2020, 03:06 AM
Archibald1's Avatar
Quoted: 2910 Post(s)
Liked: 1992
No changes. All I’ve done for the past year or two is turn it on and off to watch movies or play games.
It does sound like handshake issues to me as well. I’ll try the other port. That’s a good idea, and much easier than fishing in a new HDMI cable.
Speaking of, any suggestions on a good HDMI cable should I end up needing to replace it? I’ve read the Monoprice cables are questionable. I would need to measure the cable that’s on there now to be sure, but it’s probably 20’ or better.
For longer lengths I think you need to go fibre just for the integrity of the signal and irrespective of resolution. Ruipro are good.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up." Stephen Hawking.
"Be water my friend." Bruce Lee.
Archibald1 is offline
post #1622 of 1629 Old 06-30-2020, 11:03 AM
DrA
DrA's Avatar
Quoted: 158 Post(s)
Liked: 47
plastic front lens replacement
My cleaning lady used a harsh chemical on the lens and now it is useless. where can I find a replacement? Do you think polishing will help the foggy central area? I didn't know the lens was plastic.
Improvise, adapt to the environment, Darwin, **** happens, I Ching.
DrA is offline
post #1623 of 1629 Old 06-30-2020, 01:35 PM
aoaaron's Avatar
Quoted: 261 Post(s)
Liked: 64
Can you guy so 3D on your HW40ES?
I tried on mine and it was awful and un-useable. VERY dim. this on an ALR Screen.
Display: 77'' CX LG OLED, Valve Index, Sony PJ + Draper React 3.0 ALR
Audio: Arendal 1723S Tower S, 1723S Centre, 1723S Surrounds, KEF Q50a, BK Monolith Plus
Powered by: RTX 2080/8086k, Denon AVR, PS4 Pro, Nintendo Switch
aoaaron is offline
post #1624 of 1629 Old 06-30-2020, 03:16 PM
Archibald1's Avatar
Liked: 1992
Can you post any pictures of the damage?
What on earth was she doing touching a projector lens anyway?
It may be easier to get the cleaner to pay to get a new lens fitted at a Sony service centre. Does she have public liability insurance?
DrA likes this.
post #1625 of 1629 Old 07-07-2020, 02:50 PM
DrA
DrA's Avatar
Quoted: 158 Post(s)
Liked: 47
Hi Archibald1,
here is the picture.
Also I left my PJ on then she was just trying to clean the lens with an alcohol based liquid. Do you think the fumes got sucked in and damaged the polarizer or the panels? Will removing the lens coating or damaging the plastic lens can cause the cross hatch artifact and blurriness? I am hoping that only the lens is damaged because I found the whole Sony OPTICAL UNIT ASSEMBLY from an older model. I can just replace the lens. Can't find a new OPTICAL UNIT ASSEMBLY for this model.
ID:	2754402   Click image for larger version
DrA is offline
post #1626 of 1629 Old 07-07-2020, 04:01 PM
Archibald1's Avatar
Liked: 1992
Hi Archibald1,
Hi.
I actually meant pictures of the lens itself.
Alcohol based liquid should evaporate if left, but if the unit was on when it was cleaned and the lens was warm then it could leave a sort of hardened residue.
The pictures you posted look like nothing I have seen before. I can't see fumes doing that but maybe some liquid in the form of mist got in somehow.
When you say you have found an optical assembly for an earlier model, which model is it? If it is from an earlier HW,. then chances are the lens should swap with yours, but it is by no means certain. As to your actual symptoms, the grid looks well focussed for a lens that is cloudy. The images tend to suggest that something else in the optical path is afoot. Or even maybe a processor issue.
Try disconnecting the unit from the mains for 30 minutes, to see if it changes anything when plugged back in.
post #1627 of 1629 Old 07-07-2020, 09:03 PM
DrA
DrA's Avatar
Quoted: 158 Post(s)
Liked: 47
Hi.
Thanks for your encouragements. I went up there and was trying to take a picture for you and
I diagnosed the problem with 100% certainty. It is the lens. When I rotate the focus ring the artifact turns with it. The lens looks not shiny in the middle. Maybe these plastic lenses or their coatings are not resistant to alcohol.
The Optical Unit Assembly in the picture is for VPLHW30ES. Both 30 and 40 models have 1.6 zoom lenses and look the same. It is around 10 times cheaper than my 40ES's current market value so it is worth to try to swap the lenses right? After my new 295 comes on this Friday, I will take this down and play with it. I heard there is a high voltage risk though. I am OK with work like this. I built all my PCs and HTPCs. I wish PJs have interchangeable front lens capabilities.
Archibald1 likes this.
DrA is offline
post #1628 of 1629 Old 07-08-2020, 09:41 AM
Archibald1's Avatar
Liked: 1992
That is something then. Nailing down the issue makes it much easier to know what needs doing. Looks like a coating has been taken off the front of the lens. Or worse whatever was used even took some material off the front of the lens.
The chassis between the 30 and the 40 are essentially identical. So you would only have to remove the lens (carefully as any ribbon cable connected to it will be fragile.
The lens is mounted with the four screws I have indicated on your picture.
With the lid and front panel off, you 'should' be able to remove the lens on its own and swap them over.
Good luck with it and take your time. Easier to do of course if you have another projector coming!
See your Private Messages too.
Name:	VPL-HW30 optical block amended.jpg
DrA likes this.
post #1629 of 1629 Old 07-10-2020, 08:48 AM
Soxfan111111's Avatar
Quoted: 42 Post(s)
Apple TV issue, possibly lamp related?
So I am having a really strange problem that I cannot wrap my head around. I have the 40es projector, a 3rd generation AppleTV, a PS3, and a Roku Ultra.
I recently changed the lamp in the projector. As soon as I did that, I began having an issue with the AppleTV related to the image. It’s a very subtle stutter in the image. It’s silent, infrequent, inconsistent, and usually related to movement in the image. It’s like a millisecond-long skipping forward.
It happens with no other device except the AppleTV. It even happens if I switch out that older AppleTV with another recently purchased AppleTV 4K I have in another part of the house. It also doesn’t seem to ever happen while using Netflix. Only Amazon Prime and ITunes purchased movies that I can tell so far. The AppleTVs are fully up to date with their software. I did not have this issue prior to switching in the new lamp.
Can anyone make any possible sense out of this?
Soxfan111111 is offline
computer , hw40es , Sony , VPL-HW40ES
