Blown bulb - mercury vapor hazard - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By kreeturez
  • 1 Post By Verge2
post #1 of 12 Old 01-01-2015, 03:06 PM - Thread Starter
zgeggy2k's Avatar
Unhappy Blown bulb - mercury vapor hazard
Hi,
A few days ago, my wife and I were watching TV on our projector (which is mounted on the ceiling about 5 feet behind us). The projector (Optoma HD33) made a loud pop and the image went dark.
A little bit of research showed the likely cause: an exploded high pressure mercury bulb. The manual didn’t say anything about Mercury, so I just took the projector out of its mount and set it on a table in an adjacent room. When I opened it, the lamp had a housing and there was broken pieces of glass everywhere.
I took the housing and tipped it over to recover the broken glass before performing the disassembly to get to the bulb. I also vacuumed the inside of the projector as I saw a few pieces of glass had shattered inside of it.
As I got to the bulb, I realized there was a Hg symbol written on it. It is an Osram P-VIP bulb, which, if I’m not mistaken, houses about 30 mg of Hg, about 10x more than your typical CFL.
Now I’m worried about the following:
1) when the blow up happened, the projector was running, and so were its cooling fans. As far as I understand, when a bulb breaks in a running projector, Hg is in vapor form. I suspect the vapor got blown by the fans outside of the projector and got “sprinkled” in the living room around the projector (probably over my wife & I + more). Doors were closed (it was night time and cold).
2) the “sprinkled” area described above contains a playground for my 1 year old daughter. She spends a lot of time there, and close to the ground.
3) we did not vent the area (the living room is approx 50 m^3) until today (3 to 4 days later), where we aired/vented the whole house for about 1/2h (all windows open everywhere) – it’s winter time
4) the full house fan/heater has been running almost non stop since the breakage, potentially spreading Hg vapors around
My mistakes:
1) not venting the area immediately
2) using a vacuum to get shards out of the projector
3) not knowing how to deal with a projector bulb explosion
I’m obviously concerned that my house may be contaminated to dangerous levels especially in areas near the projector (where the bulb exploded) which is where my 1 year old often plays.
It’s an 1800 sq ft house.
Because it wasn’t a spill (there is no visible Hg or beads or anything of the sort), it’s difficult for me to find “what to clean up”. It’s invisible.
Do I need to worry?
Is it worth measuring my family’s exposure (urine test?) and measure Hg levels in different parts of the house?
Maybe this is silly and it's unwarranted concern (I hope). If so, please tell me!
Your recommendations are highly appreciated.
Many thanks in advance for your time.
-- Greg
zgeggy2k is offline
post #2 of 12 Old 01-01-2015, 06:16 PM
jh30uk's Avatar
Quoted: 33 Post(s)
Take off the tinfoil hat and replace the bulb and get on with your life.
jh30uk is offline
post #3 of 12 Old 01-01-2015, 06:49 PM - Thread Starter
zgeggy2k's Avatar
I take it you think this concern is unwarranted. Would you care to explain why?
I'm mostly worried about my 1 year old because she's just crawling in that area (with nose close to the ground).
Yes, it may sound ridiculous, but when you have a baby your protecting instincts kick in to 11, possibly into overreaction.
I'd feel a lot better if I understood why it's not that big a deal. I hope it's not too much to ask.
Cheers!
-- Greg
zgeggy2k is offline
post #4 of 12 Old 01-01-2015, 07:08 PM
Wdawg1000's Avatar
Check this link for broken cfl. I think cleanup should be similar.
http://www2.epa.gov/cfl/cleaning-broken-cfl
Good Luck
Bob
Wdawg1000 is offline
post #5 of 12 Old 01-01-2015, 07:21 PM
kreeturez's Avatar
Quoted: 505 Post(s)
Liked: 406
Because the bulb in a projector isn't exposed to the environment due to its housing, most of the hazard is contained, save for the vapour itself (there's thus little risk of glass or powder landing on the carpet, for instance). So the primary clean-up procedure is ventilation.
Also while the vapour itself is unsafe, the quantity isn't absolutely massive: it's almost certainly fully dissipated at this point. I doubt the carpet is still (or was ever) at risk. Likewise due to your living room's reasonable size, it's unlikely that the degree of vapour exposure your family had from the burst would put you guys at significant risk. I'd rest easy at this point
d_m1010 likes this.
BenQ HT2050A Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
kreeturez is offline
post #6 of 12 Old 01-02-2015, 04:19 AM
Verge2's Avatar
Quoted: 916 Post(s)
Liked: 244
You might have inhaled about a can of Tuna worth, I bet you'll be fine.
d_m1010 likes this.
Verge2 is offline
post #7 of 12 Old 01-02-2015, 06:42 AM
dovercat's Avatar
Quoted: 202 Post(s)
Liked: 107
The hazard is the mercury vapor in an enclosed environment being inhaled in a quanity sufficient to cause poisoning. Breathing in mercury vapor is hazardous because inhalation leads to it being absorbed into the bloodstream. Mercury vapor even small amounts in an enclosed area can cause health problems due to inhalation, the vapor is also absorbed to some extent via the skin. Signs of poison would be coughing, breathlessness, chest pains a tigh chest or burning feeling in chest, feeling irritable and nervous, shaking tremors, coughing up blood, difficulty breathing.
Once the mercury vapor has dispersed the hazard form mercury is far far less. Very little mercury is absorbed by your body if you swallow a small amount of liquid mercury or get it on your skin for a short time. This is considered almost non-toxic and highly unlikely to cause symptoms.
The other hazard of mercury is that once absorb into the human body it stays in the human body and eventually if you absorb enough over time you can suffer mercury poisoning due to the sheer quanity of mercury in your body.
If you have any concerns about how much mercury you have absorbed a simple blood or urine mercury test should set your mind at ease.
dovercat is offline
post #8 of 12 Old 01-02-2015, 07:13 AM - Thread Starter
zgeggy2k's Avatar
Thank you
Thank you guys. Appreciate the suggestions & wisdom.
Now let's see if some superpowers come out of this!
-- Greg
zgeggy2k is offline
post #9 of 12 Old 01-02-2015, 07:37 AM
flight planner's Avatar
Quoted: 24 Post(s)
I just have to add my $0.02 here.
I'm 74 years old and as a young boy I often would purchase Mercury at a local chemical company and play with the metal.
We used to use it to coat nickels and dimes to make them much shinier and we used our bare fingers to do all of this.
I'm still very much alive. <G>
flight planner is online now
post #10 of 12 Old 01-02-2015, 01:02 PM
dreamer's Avatar
Quoted: 1500 Post(s)
Liked: 607
Yes, and think how much smarter us old farts would be if we hadn't chewed on the lead pellets for our pellet guns when we were kids that didn't know lead was bad for us.
Politicians have passed all these hazardous warning label laws on the assumption that it can't hurt to be too careful, but they neglect to think about the cost of the paranoia and product liability lawsuits that follow.
If the amount of mercury in a UHP lamp was really dangerous, they would have been banned and all lamps would be Xenon or LED sources by now.
Kirk Ellis
BenQ TK800 VuTec 122" Screen, Harmon Kardon AVR 247
Psycoustic Mark III L&R Towers, Boston Center, Energy Take 5 Surrounds
dreamer is offline
post #11 of 12 Old 01-02-2015, 01:24 PM
Bohanna's Avatar
Liked: 24
Use a pair of throwaway vinyl gloves when you are cleaning out the pieces. Wipe up any shiny surfaces in the immediate area with a paper towel. Make sure the filter is cleaned to allow for better cooling. Expose the child to intense light for 5 minutes then put the child in a dark room. If the child glows call the EPA and ask to speak to Barry O He will tell you how to whip up an antidote!! Bohanna
Bohanna is offline
post #12 of 12 Old 01-02-2015, 02:13 PM
dovercat's Avatar
Quoted: 202 Post(s)
Liked: 107
If mercury is swallowed less than a thousandth that is less than 0.1% is absobred by the body.
Tuna contains abourt 0.2 parts per million.
Likewise skin aborption of liquid mercury is insignificant compared to inhaling mercury vapor.
A projector lamp contains about 30 mg of mercury and it is in vapor form and under pressure, if the lamp explodes it is released into the room in vapor form.
If inhaled in vapor form it is readly absorbed into the blood 80% absorption.
An adult can suffer effects of poision from absorbing as little as 0.25mg.
What makes it safe or not is the size of the room, which determines the amount of mercury vapor you are inhaling, and how long you stay in the room.
Once mercury is not in vapor form it is far far less hazardous.
dovercat is offline
