Poll: What ceiling mount are you using? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #31 of 35 Old 02-08-2020, 04:12 AM
Quoted: 100 Post(s)
Liked: 53
Moving to a new house next month and in initial planning stage, new to tv projection. Can anyone tell me if my idea to build an overhead projector shelf with black cloth Instead of a mount is a bad idea? Wondering because so many seem to use mounts instead of a shelf. BTW, probably be an Epson 5050 with a 2.35 screen.
DavAbq is offline
post #32 of 35 Old 02-08-2020, 09:59 AM
descalabro's Avatar
Quoted: 509 Post(s)
Liked: 200
I made my own mount from perforated metal corner profiles and bolts. It's not mounted on a ceiling, but it could be (using proper dowels). It allows for some horizontal rotation (I would say 10 to 15 degrees, although the projector has to nudge) and horizontal leveling. Very sturdy, very cheap, not heavier than the common mounts. Mine is very rough on the edges, but if cut, polished and painted, will look great.
ID:	2682164   Click image for larger version
ID:	2682166   Click image for larger version
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | JVC X30 (RS45)
descalabro is offline
post #33 of 35 Old 02-11-2020, 10:54 AM
Azekecse's Avatar
Quoted: 164 Post(s)
Liked: 111
Utilizing a Chief RPA Elite Projector Mount, which came with my Epson 6040UB. I love the fine adjustments and sturdiness of this mount. I would highly recommend it. I am now using it for my JVC NX-5, which only needed the JVC mounting plate.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX5/Elite Lunette 2 120"
Azekecse is online now
post #34 of 35 Old 02-11-2020, 03:26 PM
Russell Burrows's Avatar
Quoted: 95 Post(s)
Liked: 31
Red face
Lg pf1500 Steren mount 20 dollars all steel.
Height adjust ?
Easy just diy drill and cut to ht.
Will buy again.
Denon 4k avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount at diy 135 inch screen triple 15 boss build .
Pending buy quality components for some new point source mains new 4k lg hu70la projector 1240 cubic foot ib for 16 fi car audio ib318 v2 subwoofers 4 nx3000 dsp
Russell Burrows is offline
post #35 of 35 Old 02-12-2020, 11:46 AM
rads03's Avatar
Quoted: 13 Post(s)
Liked: 3
chief mounts since 2006. love them. never had a single problem.
rads03 is online now
