Optoma HD33 - Power Supply / Board Replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-24-2015, 05:01 AM - Thread Starter
Liked: 0
Exclamation Optoma HD33 - Power Supply / Board Replacement
Just pulled apart an Optoma HD33 that would when powering on would never get past the flashing blue LED on start up. After removing the main board and taking out the power supply / board I found charring where the 68uF 450v capacitor attaches to the board. I am in the Toronto ON Canada area and looking for advice on where to ppurchase the new power supply online. Any assistance would helpful?
ID:	1014089   Click image for larger version
KentoBento is offline
post #2 of 5 Old 01-30-2017, 10:49 PM
bmbk's Avatar
Guys, i am having powersupply as well. found out one of the chip has melted. So i want to try to replace the board before sending to Optoma,
Any help where i can get them or will Optoma sell it to me ? I have email them no reply yet.
bmbk is offline
post #3 of 5 Old 01-31-2017, 01:37 PM
Liked: 0
I have HD3300 with optical lens burnt. I tried to replace it but the lens bought from ebay does not fit. I can sell parts you needed if they are same for HD33.
avs5b is offline
post #4 of 5 Old 01-31-2017, 10:14 PM
bmbk's Avatar
Hi,
I am not sure how identiticial they are, but if you have any photo of the power unit, then it will be good.
btw, where u from ?
bmbk is offline
post #5 of 5 Old 02-01-2017, 05:38 AM
Liked: 0
Hi,
btw, where u from ?
Stamford, CT. I will open it on Friday and take pictures/model # of all the parts.
avs5b is offline
hd33 , Optoma , power , problem
