Need your opinion for a projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-27-2015, 12:36 PM - Thread Starter
Liked: 1
Please guys and girls, i just need a opinion if i do the right thing. I almost ready to buy the optoma hd141x. I choose it cause it's one of the cheapest 1080p projectors. You all going to say to go for the benq w1070 but i live in ****ing greece and my salery is low. I think for 540euros it's a good choice. I never had a projector so don't know almost anything about them. I have read some rewies and seems that some aren't happy with it. So just need an opinion from you. Pls let me know.
Thank you.
geodex is offline
post #2 of 7 Old 10-27-2015, 02:40 PM
Ftoast's Avatar
Quoted: 2688 Post(s)
Liked: 877
The 141 has a few limits that might or might not matter.
-It doesn't have many input options (skips most/all analog inputs), so hdmi is basically mandatory.
-Its color-brightness is very low, so you'll either want to keep to a modest screen-size or you'll need to suffer more inaccurate settings to light-up your screen.
-Its colorwheel is slow, so it is a poor choice for anyone that's rainbow-sensitive.
-Its zoom is limited and it doesn't have any lens-shift, so you'll want to use something like the calculator at projectorcentral.com to pin-point where you'll need to mount it.
With all that in mind it's a solid projector with a very low price.
You might want to check prices on the older w1070 and newer Vivitek 1186 in your region, otherwise that Optoma is not a bad choice if the above are too much more expensive or you require 3D and can't find an inexpensive Epson 8345r.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 7 Old 10-27-2015, 04:21 PM
Liked: 4
In terms of noise Optoma HD141X is inconstant in quality, some units noticeably louder that other.
So it is better to check it in person before buying.
elRaid is offline
post #4 of 7 Old 10-27-2015, 04:30 PM - Thread Starter
Liked: 1
Thank you very much.
I have already checked other projectors and mostly the benqw1070 that all talk about, but all are more expensive.
geodex is offline
post #5 of 7 Old 10-27-2015, 04:31 PM - Thread Starter
Liked: 1
Thats a problem, if i buy it i will order it from italian amazon. :/
geodex is offline
post #6 of 7 Old 10-27-2015, 04:57 PM
Ftoast's Avatar
Liked: 877
I take it Italian Amazon (that's a fun phrase) and return-policy aren't exactly hug-basis friends..
Are there any local stores/shops with decent return-policies you can take unfair advantage of, or better yet, local shops with some form of price-matching and a backup exchange/return?
The 141 tends to be weirdly messed up in its fan-dampening, which its twin-sister the hd26 got right (but is otherwise exactly identical despite lying manufacturers specs and a $100+ price increase).
This is another reason the w1070/1075 and Vivitek 1186 (or Vivitek 1188 if gaming isn't a major concern) is brought up..if pricing in your area is close enough..well, you'll be getting both a better picture possibly and a more consistent build.
IBDT..at this very second, so I might be a bit handicapped.
I don't mean to harp on something outside of your budget (and am sorry for rubbing it it likely far too often) but I only bring up the other models because the price difference in the US/Canada is quite small. Not truly couch-change small, but nearly.
Ftoast is offline
post #7 of 7 Old 10-28-2015, 04:46 AM - Thread Starter
Liked: 1
The cheapest 141x in greece is about 100 euros more expensive than the one on amzaon (incl. shiping cost). The cheapest 141x i could buy is about 630 and the benq 1070 is about 785 euros (non iclude shipping cost, thats at least 10$). And the odd thing is that the prices are always rising the last months. Will give it a good thought. Thank you for your advice.
geodex is offline
1080 , buy , dlp , Optoma , projector
