How can projects provide insane static 30000:1 contrast ratio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-02-2015, 10:21 AM - Thread Starter
Quoted: 141 Post(s)
Liked: 5
I saw reviews of some very high-end and very expensive projectors supposedly having very high static contrast ratio of 30000:1 ! How is that possible? There is no way for projectors to produce plasma-level black levels no matter what background is used. The only way I see it possible is if these projects could provide VERY high brightness. Is that so? If not, then how do they provide such high contrast ratio?
Probes: i1Pro 2 & i1D3
Software: HCFR, DisplayCAL+ArgyllCMS, madVR
HDTV: Samsung LN40B550 40" CCFL SPVA LCD @ 1080p, 60Hz, 2700:1 CR; Monitor: LG 32GK850G-B 31.5" LED MVA LCD @ 1440p, 165Hz w/ G-Sync, 2500:1 CR
HTPC: i7 8700K @ 5Ghz, 16GB 3200Mhz RAM, GeForce GTX 1080 Ti, Windows 10 x64 1809-17763
Masharak is offline
post #2 of 9 Old 11-02-2015, 10:53 AM
t-n-o's Avatar
Quoted: 69 Post(s)
Liked: 33
No, they don't need much brightness, they need the ability to block the lamps light during dark scenes, but you need a fully darkened room to get that contrast, screen doesn't matter. The better they block it the better the on/off contrast. Even e very dim projector is able to achieve a very high contrast rating if his blacklevel is good enough.
t-n-o is offline
post #3 of 9 Old 11-02-2015, 11:18 AM
Ftoast's Avatar
Quoted: 2696 Post(s)
Liked: 889
^^^That.
Also, so far the only (non-CRT) models that can truly hit 30,000:1 contrast are specific JVC LCoS models, dual inline DMD DLPs (so far only available for commercial installation) and a direct laser-scanning projector that functions very much like the old CRT projectors (and is currently sporting some significant flaws in the present iteration).
So two of these are years from being completely viable public options while the JVC starts around $3000-3500.
All three are able to not only match, but exceed the contrast of most non-modified plasma televisions by a decent degree.
Everything else I've seen measured falls at least 3X short by comparison.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #4 of 9 Old 11-02-2015, 11:31 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Originally Posted by Ftoast View Post
^^^That.
Except for the LG PF-1500.
Swolephile is offline
post #5 of 9 Old 11-02-2015, 01:07 PM
darinp2's Avatar
Quoted: 1135 Post(s)
Liked: 1767
It is amazing what they have done IMO, but we need to keep in mind that this is not ANSI CR, which uses a relatively extremely bright image at 50% luminance. This is more like a single white pixel on black. Still amazing to me that JVC can block up over 99.99% of the light for many of the pixels in such a pattern.
ANSI CR with lenses will probably never get that high and fortunately doesn't need to because our eyes don't need that much CR for such a bright image. Our eyes themselves have washout from bright objects to dark areas, but that isn't as limited with very small bright pixels on black.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #6 of 9 Old 11-02-2015, 01:11 PM - Thread Starter
Quoted: 141 Post(s)
Liked: 5
What is the usual cd/m^2 brightness for such high-end projectors? Any idea which projectors IMAX uses? When I watch films in IMAX theaters, I find black levels to be slightly better than those of good VA panels without local / micro dimming, but nowhere as good as plasma-level black levels.
I don't quite understand the whole light-blocking. I figured if a scene uses pure black somewhere, then the project would simply not use any light for that section in that scene. I also find plasma black levels to be much deeper than natural black levels of a very dark room (like the one in common or IMAX theater) to be nowhere as good as those of a plasma display. So, no matter how well a project can block light, black levels can't be that good, UNLESS brightness goes over 200 cd/m^2 or something like that.
Masharak is offline
post #7 of 9 Old 11-02-2015, 02:48 PM
Ftoast's Avatar
Liked: 889
Most IMAX use a pair of 2000:1 contrast DLPs nowadays unless they are still rocking the film projectors which I believe measure higher though I sadly don't know how much.
A good VA can measure around 3000:1-4000:1 while a good plasma can hit 8000:1+ and a cheaper LCD will limit around 1000:1-1500:1.
A majority of commercial theaters measure 1800:1-2200:1.
A high-end LCD Epson 5025/5030 or LCoS Sony hits 4500:1-6000:1 while a JVC LCoS can reach well beyond 10,000:1+ as can AMOLED.
The noticeably poorer blacks you're seeing at IMAX rooms is due to safety regulations. A well-thoughtout hometheater can reach much deeper blacks by lacking sconces and EXIT signs and walkway lights and even using particularly dark fabric on surfaces closer to the screen in some cases.
My own "theater" room is blindingly dark when lights go down, and I did it for cheap and in a very easily reversed way.
Ftoast is offline
post #8 of 9 Old 11-19-2015, 04:35 PM
Quoted: 5006 Post(s)
Liked: 1926
The projector has only a single light source, so the only way to "not use any light for that section" is to block it.
A bright home theatre projector is about 15 ftL, or 50 cd/m^2.
Dominic Chan is offline
post #9 of 9 Old 11-19-2015, 04:58 PM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1150
I own and use all of the above and these numbers are dead on.
AMartin56 is offline
